Where did my clock go?
A forum for the Nissan Armada, Infiniti QX56, and beginning in 2014, the Infiniti QX80
Qatarded
Car: Nissan Armada LE 2009
hi Folks
I've had my 2009 Armada LE since new and 2 weeks back (when returned from workshop for service) the clock in the top right of the front Nav screen has disappeared, I can see the outside temp but no time.
I've tried trawling the manual, internet, forums and whilst I've seen a couple of others have the same issue, no solutions are given.
I checked that the clock is "shown" under Settings and everything else seems to work fine.
The only issue I've had recently is that I did have to reset the factory GPS navigation to a known location (it thought I was in the sea), could this have anything to do with it? It seems to work fine.
BTW, I've disconnected the Battery for 60 secs to see if this helps but nothing.
Can any of you help?
Cheers
Qatarded
Update:
Did some digging around and managed to find instructions for the AV unit self diagnosis. Its returning an error for the GPS antenna. Seems a bit strange as it was working okay I thought but don't use it much.
Can't be sure the guys in the workshop didn't play around behind the dash etc (it was in for AC problems).
Any ideas? Do I need to start stripping the interior to check connections?
Outkast
Car: 05 Titan 4WD CC, 00 Maxima SE 5spd, 91 TTZ
If you're talking about he A/C mode door actuator recall then you actually have to take out the BCM, Bose amp, and satalite controller to get to the actualtor. Look under there and make sure the pinkish attenna harness is still connected ad look at all the hrnesses directly above the gas pedal.
Return to “Armada Forum / QX56 Forum / QX80 Forum”
