GLE. The GXE is a base model.allensteiner wrote:mine's not an se but don't know if it's the gx or gl. has driver power seat, leather, heated mirrors, moon roof. is there any diff between them?
Are these on 5th gens as well?ROCKART wrote:Electronically controlled front engine mountLiquid filled rear shock mounts
there's a simple write up on removing it but you have to find it yourself as it's not from this forum.sixteenXnine wrote:So can the ECU be reflashed?
Or can an ECU upgrade eliminate this governor?
