This site has gear ratios listed on the specs page. The 6th gear in 6MT may seem very short but don't forget to factor in the different final drive ratios. At the highest ratio, 6MT revs 36% higher than the CVT and 12% higher than the 4AT travelling at the same speed.
Compared to my previous car, a VW GTI, the Versa's 6th gear is shorter than GTI's 5th. That is, Versa revs higher at almost 3500 rpm and GTI at 3000 rpm at 75 mph. The reason being GTI's engine can produce 50% more torque to overcome the mechanical disadvantage.
chano129 wrote:there is also a lock up torque converter which assist the vehicle in the 5th and 6th speeds.
There is no torque converter in a manual transmission. Manual transmission uses clutch to transfer power from engine to wheel.
chano129 wrote:A four speed AT (4AT) has five set gear ratio and a six speed has seven set gear ratio and so on.It is called a 4speed tranny because it only shift four times.
4AT has 5 gear ratios--4 forward and 1 reverse. It takes 3 shifts to get to top gear. It goes 1-shift-2-shift-3-shift-4.
