irax wrote:I forgot to mention that I'm in San Diego California
I bought the fwd block and rwd setup because it was alot cheaper at the timeshoot if i can get another complete rwd setup for 1k id do that to have spares lol
I am using all vq35 timing and partsI am using 02 Maxima wiring and ecuI am using 03 350z trans,fly,clutch,drive shaft
the gray/brown connecters are by the throttle? i guess I dont know when i pulled the harness the car did not have the intake or anything on it. I'll try to take some pics tonight and see what some one else comes up with.
I want to smog the car with a 3.5 so i need 3.5ecu and everything. He is not going to be putting out good numbers with VQ30 parts. Without a VQ35 ECU or a standalone non-MegaStain hes engine will perform poorly unless he's going turbo.
Modified by irax at 10:13 PM 6/7/2007
Yeah FWD VQ35s are so cheap....the maxima people that do the 3.5 swaps usually use the 3.0 timing and they make pretty good power...they usually run in the high 13s with just the swap (which is faster than the 5.5 gen maxima). But for emissions, yes VVT is a good thing to have. It's definitely going to be nice, but it's probably pretty difficult, no? We don't have smog test like you, so we don't need to worry about it, and no EGR is very nice to work with
Anyway, about the connectors, the first black one I'm not sure about..
The second one I can't tell if it's grey or blue...if it's blue, it's an o2 sensor . Here's a few pics of possible spots:
The third black one looks like it goes here:
I can't tell if it's the PS or the A/C.
The next two grey ones are confusing, but one might be a coil plug and another might go to the alternator:
The brown ones are definitely the headlights...one of those grey clips might go to the ballasts for the HIDs as well...the reason they're not in the right spot on your car is because your engine is longitudinally mounted where ours are transverse (I'm sure you knew that without me telling you). Also don't forget about the radiator fan plugs. Those confused the hell out of my friend and I when swapping a new engine into his B14 since the radiator/fans were out of the car...
Here are some other random pictures just in case. I couldn't see much with everything on the engine (IM, PS, A/C, etc.). Good luck with the swap
