Shocks, springs, sway bars, coliovers, bushings, brakes, rims, tires - You name it, this is the spot to discuss Versa suspension components and modifications!
by piratefan » Mon Feb 08, 2010 4:09 pm
I have a TPM light that, regardless of the tire pressure I try, will not go off. I have tried 33 psi (the pressure on the door frame), 40 psi and the maximum allowed by the tire, 45 psi. Does anyone have any advice?
piratefan
- Car: 2007 Nissan Versa S
by bondiblue » Mon Feb 08, 2010 4:28 pm
Get used to it is about all I can say. Ours is on almost all the time and it's at the right pressure. We had an Altima before this V and it had the same problem. Any time it started getting a bit cold, on it would come regardless of pressure.
2009 Versa Hatchback ---- 2003 Durango SXT
---- 2004 Honda 599 *modded*----
bondiblue
- Car: 2009 Nissan Versa 1.8S HB ---- 2003 Dodge Durango SXT Sport
by silverarrow27 » Mon Feb 08, 2010 6:27 pm
If it consistently stays on, take it and have the dealership fix it.
72 240z *Non-functional*
07 Versa SL
silverarrow27
by Promise Land » Tue Feb 09, 2010 3:43 am
Watch the tech feature on TPMS in the General Section.
Project: MEEP:
Versaspeed Grille
Tiida Xenon HID Projector Headlamps
APR Carbon Fiber Splitter
Custom Lower Mesh Grille
Earl's Stainless Steel Brake Lines
Tanabe NF210 Lowering Springs
Satin Black Spec-V Wheels
35% Tint
NISMO Graphics Kit
Promise Land
- Car: 2009 Nissan Versa S 1.8L H/B
Return to Versa Suspension, Brakes, Rims and Tires
