Chuck Tribolet »
https://forums.nicoclub.com/chuck-tribolet-u120862.html
Fri Nov 25, 2011 7:56 am
I figure I have about 75,000 miles towing my 2000-pound boat trailer with '95 and '01 Pathfinders. No problem.
I towed a '68 Firebird on a really heavy rental trailer about 30 miles with my '87 PF (3500 pound capacity). Not fun.
The key question is: how much does the loaded trailer weight? IIRC, a 2004 PF has a 5000 pound tow capacity, check your
owner's manual.
How much stuff will be in your truck? That will reduce tow capacity.
Watch the tongue weight. It should be 5-10% of the loaded trailer weight. If it's too low, the trailer will sway, if it's too
high you are bottoming the rear suspensions on the truck, and likely locking the front brakes when you try to stop quickly.
A trailer that size probably has surge brakes, right?
Never forget that your truck is now a lot longer. Don't change lanes a lot. Use those side mirrors. Watch the temp
gauge.
750 miles likely means more than one state. Research state trailer speed limits, they vary (California is 55 max, AZ is whatever's posted (75 MPH on rural freeways)).
750 miles in 10 hours is 75 MPH average. NO WAY.
