If you say "at least 235s on a 17 x 7 inch rim then either you are not very knowledgeable or you only care about show (looks), obviously I was mistaken. You are just simply not very knowledgeable. Sorry for the misunderstanding.
I never said that there is anything wrong with "225 on my 6.5s" I have actually recommended that setup (225/50/16) and quoted tirerack (your favorite place) by saying that you could actually squeeze them onto 6 inch rims (6.5 inch is even better and a 5 inch rim would be stupid!) but the "'recommendation' guide" that you speek of is actually a listing of tire specs supplied by the manufacturer. I was being an a$$hole, that's the ONE thing you are right about, but to tell other people that at least 235s on a 7 inch rim is best for grip is just silly!
I am truly sorry to be such an a hole, but at least 235s on a 7 in rim is just a really REALLY bad idea!
BTW it was a tirerack salesperson that sold me my 235/40/17s knowing that they were going on an S14 and they will give you wheel offsets over the phone ( I also wish the were on the web-site).
It is tricky for them to recommend wider tires, because they do not know what offset you have; and unless they have done the exact same upgrade with both tire size and offset on the exact same vehicle, then there is no perfect science to squezing wider tires under your car.
There are more knowledgeable people there and if you get stuck with another A$$ hole just tell him that you don't care about his recommendations and that you would just like to place the order.
Good luck
Now that I have been an a$$HOLE you probably will not listen to my recommendation, but the 225/45/17 Falken azenis sport is an awesome sticky tire that is the widest tire you should (based on manufacturer specs put onto a 7 inch rim.
discount tire 112 shipped will be my next tire
-SPORT
R240NA wrote:Gee sport, why you want to be an *******? You're basing your facts on tirerack? The 'performance tire specialists', who refuse to give offsets to any of their wheels and don't advise going above a 215 in any size. These are the same people who told me a 235 wouldn't even fit my car, regardless of wheel size. Great source of information, these guys are. Obviously, no, I'm not a tire engineer, neither is anyone of the 'salesmen' who read through a basic 'recommendation' guide written by someone else. I dropped over two seconds off my average autocross laptime by going to a 225 on my 6.5s, seems grip was enhanced. Why would I consider a larger tire show? Do I show my car? Have you even seen my car and know how I drive it?
