R32ONP »
https://forums.nicoclub.com/r32onp-u163432.html
Sat Sep 25, 2010 5:04 pm
ok so my car flat spots when its cold and it will flat spot untill it gets upto temp but sometimes it will flat spot for a while wen upto temp...then just randomly stop flat spotting and it will not flat spot any more... but when cold it will do it again..
sometimes it doesnt flat spot when cold
it idles mint as smooth as has no air leaks...
the TPS is set to 0.44 v and the idle switch works perfectly
is this a MAF sensor problem?
also my car cuts out at 6000 rpm (fuel cut) still driving me crazy the injectors stay off for maybe 3 seconds then come back on...does it at exactly 6000 in 2nd and 3rd gear..
it still does it at the exact time wether i do 7psi or 10 psi or 12 psi
any help would be muchly apreciated
car is a 1990 GTST type m with a RB20DET, 3 inch exhaust,std rb20 turbo and intercooler,ssqv bov,38mm wastegate,pod filter,chiped ecu
