The one you are holding (green) is for the ambient/outdoor temperature sensor. I assume you don't have the premium pack with the trip computer and the outdoor temperature display.Leo2005 wrote:Since you guys started to talk about harness for fog lights I would like to know what these 2 wires stands for? They are located right behind the grill.
Leo2005, I'm gonna split this post off as a seperate thread.Leo2005 wrote:Thanks a lot. So is there a possibility to add outside temperature sensor? Don't care much about intelli key. I understand I would have to exchange speedometer and maybe more stuff but still....
im going to venture to say that the gauge cluster(speedometer) is already programmed to accept an ambient sensor. I highly doubt that they would have 2 or 3 different clusters. I think its all the same one - and all you need is the actual module to plug into the wiring harness.Eugene@ wrote:What is the gauge cluster ? Are you trying to guess or you really know ? According to the service manual it's pretty straight forward. Ambient temperature gauge is connected directly to the combination meter. The meter itself in diagnostic mode switches on temperature segments. I suspect the only thing you should do after sensor installation is to activate it via Consult III. The main problem is where to get this device from, it's too expensive
see page 48
http://pdf.textfiles.com/manuals/AUTOMO ... 08/MWI.pdf
