What are these called? Help PLZ
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
k3vin15753
Car: Versa 07
Jeep patriot 08
I need to know what these plastic things are called on the corner of each side cause my left hand side one came off :( and i dont know how they are called to get a replacement lol
SikBoy
Car: 2007 Versa Hatchback S 1.8L 6MT
They're called fender covers. It's part of your cowl, but they are available seperate.
Francesco
[quote="k3vin15753"]I need to know what these plastic things are called on the corner of each side cause my left hand side one came off :( and i dont know how they are called to get a replacement lol
There is a service bulletin out on this problem NTB09-114b that covers 2007-2009. If you are still under warranty it should be covered.
DESCRIPTION PART
COVER-FRONT FENDER, RH 66894-EL000
COVER-FRONT FENDER, LH 66895-EL000
Frank
2009 Versa S sedan with 23600 miles and 34 MPG average over all these miles
k3vin15753
Car: Versa 07
Jeep patriot 08
Thanks a bunch guys :)
DentyCracker
Car: 2008 Nissan Tiida Latio Japanese Model
1498 cc HR15DE engine
SC11 Chassis
Thanks a lot. Someone stole the right hand one off my Tiida between the time we viewed it on the dealer's lot and when we drove out. I am assuming it didn'tfall off
veronicatheV
Car: 2010 Nissan Versa 1.6
when changing out my springs that cover as you all know has to come off, but mine unfortunately never went back on the same and always seems loose if you get a new one let me know where so I can replace mine as well please.
Promise Land
Car: 2011 Nissan Versa
2001 Chevy Suburban
1992 Ford Mustang
follow the TSB and apply double sided tape.
veronicatheV
what Technical Service Bulletin? I didnt get that I just got 4 Green Springs in a box. I had to figure out how to get to that third bolt all on my own.
And I dont think double sided tape will hold it, whenever I open the hood the corner of the hood catches it and pops it loose again. Same thing when I close it.
woodstock74
Car: 2009 Nissan Versa
SikBoy wrote:They're called fender covers. It's part of your cowl, but they are available seperate.
Argh! They're called what? Been trying to figure out the same thing and am convinced they are, "cowl grille outer covers".
woodstock74
Not to hijack this thread, but didn't want to start yet ANOTHER "what part is this"....but...what part is this? Actually, what I'm curious to find out is if there's supposed to be one of these louvered underbody panels on the left hand side of the car?
Return to “Versa Technical Discussions”
