Yea +1 on the NA oil squirtersBigTDogg (MA) wrote:The heads are absolutely different. The blocks are the same.
If you're getting new forged pistons (as I would assume you would) the NA oil squirters are actually better, and many guys swap them in when doing forged piston builds.
You can get 500RWHP reliably from a bone stock VG30DETT block, but since you're rebuilding, doesn't hurt to step up to forged pistons.
Your $15K budget is lofty, and you could get 700RWHP for that kind of money. My advice would be to budget about $5K parts and labor for the engine and turbos, then use the rest for the supporting mods and suspension/brakes. Then you'd have a very nice Z32
they are, between na and tt, i think the only differences are between autos and manualsNolimitZ32 wrote:-Cams I believe are the same (don't quote me on this I never looked into it).
depending on the cylinders, i would do a bore of 87.5mm just to clean it up, but yeah big bores don't do anything.NolimitZ32 wrote: -No need to bore it unless you are going all the way to 90mm and even then its not that big of a difference
-All in all the only rotating assembly that's worth it that I know of, would be a JUN Stroker kit ($14,000)
Agreed. A light cleaning of the walls is all that's necessary. Wiesco and Eagles are plenty good enough for basic builds. Factory TT rods are forged.vulcanrush wrote: depending on the cylinders, i would do a bore of 87.5mm just to clean it up, but yeah big bores don't do anything.
the jun kit is a waste of money, imo, there are better alternatives for your money.
IMHO, the JWT Sport 530's are tough to beat. Great response, very streetable. With breather mods (2.5" intake and IC pipes) the Sport 700's are an excellent choice. Garrett is also releasing their billet turbos this year, kits to follow.z32loverboy wrote:alright cool thanks for the move guys, the more help the better.
what size turbo shouls i go with, whenever I get one?
a good tune is important, i think more important than any forged internals.z32loverboy wrote:alright, I know it's a good idea to go with forged pistons, but could i get away with oem TT pistons without roasting one or it is too iffy if they'll hold up? It was brought up that a bone stock vg30dett could make 500 rwhp. As you can see I'm wanting to cut cost a little, but if I can't... I can't and I'll deal with it.
vulcanrush wrote:a good tune is important, i think more important than any forged internals.z32loverboy wrote:alright, I know it's a good idea to go with forged pistons, but could i get away with oem TT pistons without roasting one or it is too iffy if they'll hold up? It was brought up that a bone stock vg30dett could make 500 rwhp. As you can see I'm wanting to cut cost a little, but if I can't... I can't and I'll deal with it.
500rwhp isn't cheap
i wouldn't run a stock engine pushing that kind of power, a mint-condition factory engine, maybe, but these are 18-year-old engines.
yesz32loverboy wrote:better question: are the oem TT connecting rods forged?
