Shocks, springs, sway bars, coliovers, bushings, brakes, rims, tires - You name it, this is the spot to discuss Altima suspension modifications!
by kruuth » Tue Mar 20, 2012 1:59 pm
My tpms light flashes 60 times when I fire up the car. Then it stays solid. All my tires are inflated to the proper 32lbs. Is there something I need to do here?
kruuth
by mmkeller » Tue Mar 20, 2012 7:32 pm
Sounds like a bad sensor. Mine does the same thing but I have no tpms.
Konig Illusions|Stillen lip|LED interior lights|
Doc's illuminated kick plates|painted interior trim|Takeda intake|Eibach pro kit
Alpine sound|35/5/20% tint
mmkeller
- Car: 2008 Altima Coupe 2.5
by kruuth » Wed Mar 21, 2012 4:00 am
Great....how do you fix it?
kruuth
by mmkeller » Wed Mar 21, 2012 5:58 am
Dealer.............they will check it out and replace/reprogram if needed. That is if you want them to. I don't have them and live with the light, of course I check my pressure every 2 weeks.
mmkeller
by SHIFT_COUPE » Wed Mar 21, 2012 8:49 am
I despise the TPMS. I think it causes more frustration that the benefits it provides. Just check your pressure every so often as suggested above. Don't rely on that light on the dashboard.
-Tyler
Borla Exhaust, Racingline Y-Pipe, Racingline FSB, RSB, Endlinks, Racingline Short Throw, Injen Intake, UpRev Tune
SHIFT_COUPE
- Car: 2010 Altima Coupe 3.5 SR 6MT
by JdsCoupe » Sat Mar 24, 2012 7:20 am
Same thing happened to me, they wanted 200$ for a new sensor. The reason it comes on is weak batteries inside the TPMS. Only way to change the battery is to change the sensor and recalibrate. They told me the older the car gets, the more it's going to happen so unless you're going to sell the car soon or they'll do it for free, it's not worth fixing. Just check your pressures manually like everyone else said and let the light be.
JdsCoupe
- Car: 2008 Nissan Altima Coupe 3.5SE
by kruuth » Sat Mar 24, 2012 7:02 pm
Car is an 09 with 60k so I thought the sensor dying was a little weird. Maybe a reset or something?
kruuth
by JdsCoupe » Fri Mar 30, 2012 3:28 am
I got an 08 with 35k miles, I thought the same thing. But it wouldn't need to be reset. Only thing that would trigger the light besides a bad sensor would be over/underinflation. Have you manually checked your tires? Sensors on stock tires are meant to operate at 34-36 psi.
JdsCoupe
Return to Altima Suspension, Brakes, Rims and Tires
