Speedy13 »
https://forums.nicoclub.com/speedy13-u76509.html
Wed Sep 19, 2007 4:50 am
Whats up... My car is a 1999 Maxima SE, 5-Speed, just over 93k miles... Earlier this week its started making this kind of a clicking noise... It doesn't do it when the clutch is pressed down and its louder in lower gears. Its also more noticable at lower RPM's... it doesn't do it if I hold the clutch in and give it a lil gas... It sounds like it may be coming from the rear bank but its hard to tell... Also, I noticed the same time that on start up it idles high, like 12-1500 RPM's... Once I drive it a couple blocks though the idle settles down to the normal 600 or so RPM's(at idle). This guy told me to add some injector cleaner for the idle, so I used Lucas brand... No help though... I think the noise got worse after I added it... Any help is much appreciated. Thanks in advance...
Edit... The car doesn't have any problems driving or anything yet, and I don't have any issues shifting into or out of any gears...
Modified by Speedy13 at 9:13 AM 9/19/2007
