rgk »
https://forums.nicoclub.com/rgk-u245656.html
Mon Mar 16, 2015 5:39 pm
This annoying rattle is caused by the rear shock absorber, specifically where the shock meets the upper bracket. Yep, I'm the guy squatting in his luggage area, listening for the noise, while his wife circles the Wal Mart parking lot.
Twist each shock by hand and see whether the offending side makes a slight metallic noise when twisting. It should not.
If it does, try tightening the nut and bolt. If your shocks are worn, this will not help. You will have to replace the shocks.
I replaced my shocks, and the sound went away... for about a week. I lived with it for a while until seeing this resurrected thread (don't apologize!), which inspired me to tighten the nut and bolt at the upper mount. This solved the problem. For how long? We shall see. If the nut and bolt continues to loosen, I may look into replacing the bracket altogether.
