KoopaTroopa »
https://forums.nicoclub.com/koopatroopa-u128221.html
Thu Jan 26, 2012 2:19 pm
S13 btw,
After pulling out my wet moldy carpet I found that the water was running down the seam behind the ECU. I suspect the drain tubes from the sunroof to be responsible. I've already checked the rear drain hole (goes straight down the B pillar area and is easy to follow), it checked out just fine. The forward drain tube, however, the one that runs down inside the A-pillar is difficult to follow. Anyone know where this drain spits out? Also, Ive got another mysterious tube which seems to start in the same area as the rear B-pillar drain, it's smaller and runs along the side rocker panel on the inside toward the front of the car. Where does that one end up?
If I've confused anyone I can take some pictures.
