Mouse6933 wrote:this makes clear sense to me that if u tried using s14 pump, since one bolt whole dont line up it would leak /be a big issue... but on frsport its stated that "S14 SR20DET water pump is also considered as an "upgrade" for S13 SR20DET motors due to the fact of redesigned pump for better flow. It bolts up the same on the S13 SR20DET, but does not use one mounting hole that the S14 has. Many has done this small upgrade and is running fine in the S13 SR20DET motor." sooo i just got my extra block and head that im building and was considering this.. any info or input would be apprecitate
I have physically had both the pumps next to each other.
S14 pump
S13 pump
Notice how the impellors sit in different positions? The S14 pump is recessed into the pump itself where the S13 pump is flat and the impellor sits way out. The S14 gets away with this by having extra castings in the block to direct flow to the fins. The s13 lacks those flow castings, so while I can see the pump physically sitting in the block, I can't see it doing what it's intended to do.
This is just me talking, but I cannot see the S14 pump flowing better than the S13 pump on an S13 block. If someone can show me empirical data supporting what frsports claims (which they say in really bad english I might add), I could be persuaded to change my song. Until then, I would recommend S13 owners stick to S13 pumps and S14 owners stick to S14 pumps (not that an S14 owner could fit an S13 pump to their block)
