Desert Rat »
https://forums.nicoclub.com/desert-rat-u54558.html
Tue May 04, 2010 6:16 am
The water pump is outside the timing belt and should be able to be replaced without touching the timing belt.
That said, your service interval for that belt on a VG30 is every 60k, so if it hasn't been done in a while, and you have to do that much disassembly anyways, it's a good time to do it.
