Gilley »
https://forums.nicoclub.com/gilley-u232938.html
Thu Apr 10, 2014 4:58 am
Open the hood and remove the plastic battery compartment cover. There are three things to look for here. First, there is a large wire harness inside a rubber sleeve. Make sure there are no holes in the rubber sleeve, such as from power wire added for a car audio amp. That was my problem and some silicone fixed it.
Next, look for water coming in through the fresh air vent.
Third,look for any other places water could enter.
If all else fails, you might have a clogged AC drain hose. The hose is under the car near the right front wheel. You may be able to check it and clean it.
