Want Bluetooth Streaming In Your M? Here's How!
SmoovC
Car: '06 Infiniti M45 Premium, Brakemotive, H-Techs, KYB's, USA-Spec PA15-INFI w/ BT streaming, Kuda cell mount, Magnaflow exhaust. (CAR SOLD)
Current: 2012 Infiniti M56S, Harbour Blue, 4 pc Aero Kit
Recently, I purchased a 2006 M45, and while I am impressed with the car as a whole, being an audiophile I needed iPod integration, and the ability to use my EVO 4G as a source of music.
Here's how:
1) I used (as many of you have) a USA SPEC PA15-INFI for iPod integration. I have satellite radio, so the interface was done in the trunk, and I mounted the module in the right kick panel. This was for ease of access for possible future upgrades, and to simplify running cables to the glove box. I felt this was the best location for said iPod, as it is lockable.
2) As most may know, the PA15-INFI has provision for an "AUX" input. To enable, you simply set dipswitch 1 to on. This will allow preset #6 to toggle the aux input. Using this input, we can now use a couple of parts readily available to create an A2DP Bluetooth connection:
3) You will need an iSimple IS76 cable. This cable has standard A/V RCA type connections and power / ground on one end, and an iPod connector on the other. Disregard the yellow video connector, as we will only be using the audio portion for this application. Plug the R/L audio connectors into the PA15-INFI aux in. At this point, you will need to provide ACC power to the cable. I found the easiest way to accomplish this was to pull the center console cupholder and tap into the cigarette lighter power supply. It is in a black nylon sleeve; brown is ACC power, black is GND, and red is lighting. Connect the red wire from the iSimple to the brown ACC wire, and the black wire from the iSimple to the black GND wire. I found it easiest to route the wire towards the firewall, around the footwell, and into the kick panel location.
4) Here is the part that makes this setup cool! An Anycom Bluetooth A2DP receiver. This unit simply plugs into the iPod end of the iSimple cable, and once paired to your phone, will allow streaming! I routed this cable and unit into the glovebox, and mounted with 3M tape to the location to the right of the trunk override switch. I wanted it in a visible location to be able to check the status of the connection, as it blinks a blue LED when paired and connected, solid when paired but not connected.
All of these units are readily available on the internet; simply search for them. This is a great solution for people who want iPod integration, and the ability to stream wirelessly from a phone. I am able to listen to Pandora Radio, Slacker Radio, and Scanner Radio, plus any music stored on the phone. Additionally, I can stream my entire iTunes collection from my home computer with a great app called Jam11.
In the event that you did not opt for the PA15-INFI interface, you may also use the rear AUX jacks on your vehicle, if so equipped. You will still need a power and ground connection, as the Anycom unit does require power to function.
I hope this helps anyone who needed a solution like this, and if you have any questions, feel free to post.
theIntangible
Thanks for the post! Just curious about one thing though...
Any reason why you didn't connect the Anycom adapter to the built-in iPod port?
SmoovC
Um, because an '06 doesn't have one?!
theIntangible
I meant on the USA SPEC PA15-INFI. It looks like there is an iPod/iPhone connector and I was just curious why that can't be used.
Thanks
SmoovC
theIntangible wrote:I meant on the USA SPEC PA15-INFI. It looks like there is an iPod/iPhone connector and I was just curious why that can't be used.
Thanks
Ah ok, now I understand! lol. Thanks for the clarification. You certainly could use the iPod/iPhone connector and the Anycom to accomplish the same thing. However, you would not be able to control the unit from the stock stereo. My objective was a dedicated iPod input with on-screen control, and a wireless (Bluetooth) input for streaming; which is controlled from the phone itself.
theIntangible
SmoovC wrote: Ah ok, now I understand! lol. You certainly could use the iPod/iPhone connector and the Anycom to accomplish the same thing. However, you would not be able to control the unit from the stock stereo. My objective was a dedicated iPod input with on-screen control, and a wireless (Bluetooth) input for streaming; which is controlled from the phone itself.
I read that the Anycom adapter can interpret iPod commands (Play/Pause) and convert them to their respective BT commands. If that is the case and you connect it to the iPod connector, shouldn't steering wheel/dash commands be converted to iPod commands and then to the BT commands?
That is basically what I'm aiming for. I don't really care about having the song title displayed or preserving the iPod port for connectivity to an actual iPod.
SmoovC
In theory yes, that would work. My concern would be whether or not the USA SPEC can interpret the vehicle commands properly and transmit the required signal to the Anycom, thus out to an iPhone/iTouch. I suspect one would have better success with this method if the vehicle came equipped with a USB port from the Factory. I would be more than willing to try it, but when I got my EVO 4G, I gave my iPhone 3Gs to my daughter, and she lives out of State.
theIntangible
I just ordered the components. Hopefully I'll be able to do what I want.
Thanks for all your input!
Jims M
Car: 2006 M35.HID's, Yokohama S-4 Tires, Ipod interface, Cross drilled and slotted rotors. 08 G35 Red, Yokohama Envigors, slotted and drilled rotors. 2011 Black G37x with sport appearance package new
Does anyone know if this will work or how to steam Bluetooth from an iPad?
Now that would be hot
SmoovC
The iPad has Bluetooth 2.1 EDR, so it should be more than capable of transmitting to the Anycom.
CORROSIVE
Car: M35
How does it sound? I did not install the parts to give my stereo Ipod or Aux input... but mine were routed to the center console. When I hook up something via AUX-in it sounds terrible and muffeled. I tried to hook up my ipod touch to the ipod part, and it will not work at all... (I think it will only work with the older ipod video's). Either way, I am totally down to give it a shot and buy the Anycom Bluetooth A2DP receiver but if its just going to sound terrible... I rather save the 25 bucks I would be wasting on the receiver.
SmoovC
theIntangible wrote:I just ordered the components. Hopefully I'll be able to do what I want.
Let me know how it works out for you!
SmoovC
CORROSIVE wrote:How does it sound? I did not install the parts to give my stereo Ipod or Aux input... but mine were routed to the center console. When I hook up something via AUX-in it sounds terrible and muffeled. I tried to hook up my ipod touch to the ipod part, and it will not work at all... (I think it will only work with the older ipod video's). Either way, I am totally down to give it a shot and buy the Anycom Bluetooth A2DP receiver but if its just going to sound terrible... I rather save the 25 bucks I would be wasting on the receiver.
It sounds as good as the iPod interface, and actually better than the Factory XM. Not sure why yours sounds bad through the aux in. Maybe your volume on the source is set low? I hooked up an 80 gig iPod 5th generation through the rear console inputs, and it sounded and looked fine on both screens when playing a movie. I also tried my 160 gig Classic, but it does not output video through the headphone jack like the 80 gig 5th generation, so I need a different cable to do that. Maybe that is the issue with the iTouch?
CORROSIVE
Car: M35
I guess the safe bet would be to borrow an older gen Ipod from someone and see how that works out. Now to find a friend with an ipod classic/video....
jayfox911
Car: 2006 M35 Sport
I just did this setup and very happy with the way it works. :biggrin:
I already had the usa spec, so this upgrade cost around $80 to get Bluetooth streaming!
AnyCom
http://insidecomputer.stores.yahoo.net/adpblutipod.html
IS 76 cable
http://www.amazon.com/iSimple-IS76-Medi ... B001TH8O7O
Thanks
I first tried to get the build in ipod connector to work with the anycom however it would switch the usa spec to Aux mode after a split second of sound. not sure why but after hooking up the iSimple IS76 cable with the AUX port everything works fine.
DoN_BLaZe34
Car: 2007 M45 Sport - Sold
2006 FX45 - Traded
2014 Q70S 5.6 - Sold
2017 Q70L 5.6 - Current
So if I follow this correctly, it's usa spec aux port >> iSimple cord >> anycom receiver
In theory, couldn't you get a bluetooth receiver that connects via a headphone jack? And just buy a aux plug with the red and white plugs?
jayfox911
Car: 2006 M35 Sport
DoN_BLaZe34 wrote:So if I follow this correctly, it's usa spec aux port >> iSimple cord >> anycom receiver
the bluetooth adapter needs power
wazzu mille
Car: 2006 M45
SmoovC wrote:Recently, I purchased a 2006 M45, and while I am impressed with the car as a whole, being an audiophile I needed iPod integration, and the ability to use my EVO 4G as a source of music.
Here's how:
How did you know you had satellite (or needed to use the PA15-INFI over the PA15-NIS)? I just have CAT/RPT button under preset 3. Does that mean I should use the PA15-INFI over the -NIS unit?
SmoovC
From the Owner's Manual:
"FM-AM-SAT radio operation
RADIO (FM/AM/SAT) band select:
Pushing the RADIO band select button will
change the band as follows:
AM!FM!SAT (XM/SR)!AM
When the RADIO band select button is
pushed while the ignition switch is in the
ACC or ON position, the radio will come on
at the station last played.
The last station/channel played will also
come on when the ONzOFF/VOL control
knob is pushed to ON.
The satellite radio mode will be skipped unless
an optional satellite receiver and antenna
are installed, and an XM or SIRIUSTM satellite
radio service subscription is active."
If you have Sat radio, you will get the preview channel, which is either 1 or the weather channel; 174 IIRC.
wazzu mille
Car: 2006 M45
It's very confusing because from another post
http://www.nicoclub.com/archives/pa15-i ... 5-m45.html
I have the same as shown on the picture, and from another post was told to get the PA15-INFI.
But when I do as you say from the owners manual, I get "Invalid Channel" on the screen, meaning I should get the PA15-NIS.
This blows since I don't have an Infiniti dealer or a shop that can tell me which one to order.
wazzu mille
Car: 2006 M45
SmoovC, I"m in WA also, Kennewick. PM me your phone number and we can chat. I can't figure out how to send a private message here.
tfs1975
Car: 1991 300zx Twin Turbo
2012 M37 Sport
@SmoovC,
Thank you for your post. Since getting my 07, I feel that this is the only thing the car lacks and I have been searching for a way to accomplish wireless streaming. Most of my music library is now either on my Android phone or my Android Tablet. My question pertains to the factory bluetooth and how the Anycom works with that. I understand that the Anycom is for streaming media and the factory bluetooth is for phone only but, when you get a call does it all seem to work? Does your phone recognize and hook up to both when the car is on? I have a Motorola Droid Razr Maxx and I am just wondering if I am giving up the phones bluetooth ability for the ability to stream wirelessly. Does your EVO recognize both? Can you elaborate as to what happens when your streaming music and you have an incoming call? I have ordered everything already and plan on completing the install this weekend. I look forward to your reply. Thank You and thank you for the post. I was extremely happy to have found it.
SmoovC
wazzu mille wrote:SmoovC, I"m in WA also, Kennewick. PM me your phone number and we can chat. I can't figure out how to send a private message here.
The PM button is on the left side of the screen, just below the user name. :) No offense, but I am just not all that comfortable giving out my phone number over the internet. I hope you understand.
SmoovC
tfs1975 wrote:@SmoovC,
I am glad the information originally posted has helped. I too use an Android phone, and also a Motorola Xoom tablet. Since I recently uploaded all my music to Google Play, I find streaming even more of a necessary feature.
In answer to your questions:
You should not be giving up handsfree capability for streaming ability or visa-versa. The two will work together, and at the same time.
Yes, it all works. I have a Kuda custom cell mount, and hard wired a power connection and corresponding cord to the cell mount. I am using an app available in the market called Bluetooth Switch. This handy little app has the ability to be programmed to turn BT on / off when power is connected / disconnected. The scenario goes as such: I enter my car, plug in the phone, snap it into the cradle and start the car. Once the phone receives power, it automatically switches on Bluetooth and connects to both the M45, and the Anycom. Keep in mind it does take about 30 seconds longer to connect to the Anycom than it does the car.
You do not need this option or app, although I find it the easiest method to accomplish both charging and managing BT connections.
Once connected and streaming (say for example, Google Play) and you receive an incoming call, you may answer via SWC (steering wheel controls) or phone. The music will pause while you are in call, and resume play when you end the call via either method. All music or streaming is controlled directly from the phone, and calls can be placed or received from the car's interface (SWC's or Infiniti Controller) or the phone itself.
I hope this clears up any questions you may have had, and if I can help further, please ask. :)
tfs1975
2012 M37 Sport
Ok...Wanted to update with my experience regarding this process. Just to Recap..I have an 07 Infiniti M35 with Navigation and XM Satellite radio. I purchased the USA-SPEC Ipod Interface for Infiniti/Nissan Model PA15-INFI, purchased the iSimple IS76 cable and also purchased the Anycom A2DP Bluetooth receiver. I used the guide in the FAQ section of this forum for the install of the USA-SPEC INFI and coupled that with the write up on this thread from SmoovC to accomplish the set up. I ended up installing everything in my center console. I prefer to have everything close to me and it actually didn't take up much space. Took everything out of the trunk, completely pulled out the back seat and took out the cup holder. I was able to run the wires under the carpet and to the cup holder area without any issues. I used a dremel to make a small rectangular opening in the front of the center console. Everything works as stated in the above thread. The only issue I have so far is a tiny bit of distortion in the Driver side door tweeter. I do not hear the distortion when listening to a CD or when using the XM. I am going to go back and check the ground wire and all the connections to see if that can be the cause. I will have to report back on that. I have a Droid Razr Max and the phone does not automatically hook up to the ANYCOM. So far it has to be done manually. I also had to make sure that the phone only recognized the ANYCOM for media purposes only and not for phone. Once that was done, the car recognizes the phone and hooks up to the bluetooth as soon as the car is started. Not sure if the car supercedes the media but it seems that is what's happening. I would prefer it to recognize and hook up automatically but, either way it works. There is no sign of wires anywhere other than in the center console itself. I tried to post pics but honestly don't know how on this forum.
@SmoovC: Do you have any feedback or distortion when streaming?
SmoovC
I am glad everything worked out for you, and sounds like the install went smoothly.
As far as distortion when streaming, I cannot say I have experienced this. I have a rooted EVO 4G, running Synergy RC2 ROM. Included in the ROM is DSP Manager, which does quite alot for quality of music in either streaming or hardwired mode. What I am getting at is that if your phone has some sort of music manager like Beats Audio, DSP Manager or something similiar than it may be just a matter of a few tweaks. First thing I would check is to make sure any type of compression is turned off. Also, make sure your volume on the phone is all the way up for maximum signal. Alot of phones will cut volume to half automatically when paired via Bluetooth.
If that doesn't clear it up for you, we can perform some futher testing to pinpoint the issue.
Not sure why the Razr Max does not pair to both automatically. is there an option to "connect automatically" for both the car and the Anycom in BT options on your phone?
wazzu mille
Car: 2006 M45
Is there an advantage of streaming music through the BT rcvr (Anycom) vs. plugging into the PA15 adapter (ie, if you had an iPhone)?
SmoovC
Really, it is all about choices. I have the aux in behind the center console; I wanted to leave that available for other A/V options for the RSE, and to have dedicated streaming for my EVO 4G. I also wanted a dedicated iPod input that is interfaced through the Factory controls and displayed on screen. The setup I listed gives you: dedicated iPod interface, wireless BT streaming, and still leaves the factory A/V inputs available for other devices.
tfs1975
2012 M37 Sport
SmoovC wrote:I am glad everything worked out for you, and sounds like the install went smoothly.
@SmoovC.
Sorry for the lag in response. Easter is my annual pilgramage to see the family back in NY. I have started trouble shooting the slight distortion in the driver side door tweeter. Nothing has stopped it as of yet. These are the steps I have taken so far.
1. I checked and re-did the ground wire. Even though the manual says it is not needed, I hooked up the ground for the SPEC-USA. Nothing changed so I left it unconnected.
2. Checked all connections and plugs
3. Switched the RCA wires to see if it was the SPEC-USA receiver. The distrotion was still coming from the drivers side tweeter.
4. Hooked up the ANYCOM to my old phone (DROID 2)
5. Put songs that have the most distortion on a CD and listened. No distortion when playing music through CD or Satellite.
6. Hooked ANYCOM receiver to the dedicated IPOD wire that came with the SPEC-USA. It didn't transmit any music at all. My phone states it was connected and was playing w/o sound either in the car or through the phone. Maybe the IPOD connection will not work with Android Devices. I have hooked an IPOD to the dedicated IPOD hookup and it seems to work fine. Will have to charge up the old NANO and see if the distortion is there. It is also possible that I don't have the dipswitches correctly set up but, I think it's right.
I have checked for compression options on the phone and can't seem to find any. I also have yet to download and try a different music player. I will start looking into some. My previous car was a 2010 Lexus IS350 (too small). It was able to stream wirelessly through bluetooth media. I used both the Droid 2 and the Droid Razr Maxx with no issues or distortion. On both phones the Lexus bluetooth automatically hooked up to the car upon start up. There is no automatic option in the bluetooth menu on the phone itself. The phone pairs with the M flawlessly by itself but for some reason does not pair with the ANYCOM unless done manually. Not sure why, still trying to figure this out as well. Does the steering wheel controls work while your streaming? I would imagine that the volume works as does mine but, can you switch songs with your steering wheel control?
At this point I am starting to think that the tweeter itself is bad. It seems that the SPEC-USA has a much higher output than the regular CD player/radio/satellite. Music is considerably louder when coming through the SPEC-USA. Is it possible that the tweeter cannot handle the higher output? The distortion is still there at low volume however. The passenger side tweeter does not seem to have this problem whatsoever.
Any further trouble shooting ideas are much appreciated. Thank you.
tfs1975
2012 M37 Sport
@SmoovC or anyone for that matter.
I was wondering if you have any knowledge regarding the removal of the door tweeters. The top trim looks like it comes off pretty easily. Do you know if the whole door panel has to come off?
Any info is appreciated.
Thank You.
