Q451990 wrote:Maybe I'm overly cautious, but I don't think this is something Nissan would have messed up at the factory. Maybe there's some engine protection that's being taken out here, or some timing chain stretch that you're adjusting out - but I wouldn't recommend this for just anyone to try.
I'll give you points for trying something new though. I've owned a first gen. Q since 1996 and have spent a lot of internet time on a couple of forums, and I've never seen anyone even think of adjusting these.
Heath
You never know if you don't try right, I know when I centered them my afrs were dam near identical and the car ran much smoother. I know it hasn't hit any valves at fully retard or advanced, but I am still with you about how you wouldn't recommend this to anyone. I hear you on that one for sure, if someone takes just one of the bolts out too far and drops it inside the engine... that's real bad! Or takes all the bolts out
. They only need to be loosened one and a half turns maxx to move the cams.
Some more info on this though.
-when you loosen the bolts the spring in the cam wants to advance it from the second it is loose no matter where it is sitting, (if it's already at full advance it won't go any further) I did notice a good difference from just having them centered compared to one being retarded quite a lot in the factory set up.
- now I am wondering about just leaving them at full advance, sometimes the afrs are almost the exact same as they were when I had them centered, and when that happens the car -will not- hook up at all, it's like hitting Nos compared to when the afrs are different. So I have some new knock sensors coming as that could explain the problem to a degree, but it is still weird how the afrs were -always- pretty much the same with the cams centered and not just 40-60% of the time like they are now.
