jerryd1987 »
https://forums.nicoclub.com/jerryd1987-u188669.html
Sat Jun 08, 2013 2:57 pm
you can indeed, hal from dynosty actually runs cp pistons and eagle rods on his personal 744 rwhp(i think its 800 now) z, you can probably even use stock pistons i havnt seen anyone break them yet although might need meth due to the compression, the weak point in the engine is honestly just the rods. you can try the cometic route but its going to be pricey i would highly recommend just use a meth kit if you need it, but wait until after your tuned and see what you can do on stock compression because i know there are cars who did your goal on stock pistons and rods temporarily without det. also no need for the strongest studs....... your going to pay a ton for l19 head studs around 400-500 bucks, a better route if you go with the stock pistons is to use a HR gasket with HR bolts, no one has actually found the limit to de bolts but its just accepted the hr's are stronger plus the hr head gasket enables better cooling but it does need a little grinding done on the block.
as far as limits i wouldnt try for much past 500, when you start going beyond that your going to need alot more money invested, 9.0:1 or lower compression depending what you want to run on pump(or even stock compression if you have access to e85) cp or equivalent, larger clearanced bearings, arp main studs, billet girdle, fluidamper or ati pulley(HIGHLY recommended anyway though even lower then 500), l19 head studs, hks or dynosty headgaskets(cometic honestly arnt as good as the magazines make them out to be), larger turbo or turbos(now sure what the he351cw will put out not familar with it but i can tell you that you arnt going to be happy with the spool characteristics since its aimed at a diesel.), bigger fuel system, headers(stock become a restriction about 500 to the wheels) and more i know im forgetting atm. expect to spend around 10k for a well performing single turbo to around 500-550 to the wheels, expect about 16-20k for above that where the clutchs alone needed are 2-3k by themselves.
for common failure points rods, rods and rods, no one has pushed stock components to failure yet we dont even know the limit of stock sleeves, xkr on another forum ovaled his cylinders at something like 890 wheel horsepower(couldnt even tell till tear down car ran fine and made power) but hal runs 744 to the wheels no issues. people have ran 500 on stock compression no issues some have meth some dont depends on your area. bearings have spun alot on various power levels i attribute this to shops who have no clue what they are doing that "specialize" in the vq or nissan in general trying to use factory like clearances on high power build. the vq has bearings larger then a small block chevy and lsx and almost as large as a big block chevy, it needs large clearances especially so it can use thicker oil for higher power. i recommend 30 to 35 thous for over 550 to the wheels and 15w40 oil, almost double factory clearances.
you can try to trade in for one of those cars but after trade in the cost of a 370 is going to be 3 to 4 times the cost leaving you less money to mod, it still only holds about 500 to the wheels stock block like a hr 350z, for bigger power you have to swap to 350z hr heads because the vvel heads are a pain in the a**, all the parts are just as expensive, if doing stock block power they have overheating issues due to the vvel, and overall your taking a step backward when budget is concerned. if your looking at a r33 or supra im not sure if your in the states or not but you will be looking at around 30-50k for a federal legal one, for the supra your looking at 20-30k, both platforms have there own host of issues dont be fooled by the "it will hold 700 stock block!" hype, sure but again just like anything else its a time bomb, you will notice even for both those cars people start building the engines around 600-700 whp and again they have there own issues. not to mention the fact a 800 whp r33 will be utterly unstreetable due to the smaller displacement but the vq35 is right at home with it, and both platforms are just as expensive as a 350z to modify. the supra especially needs major headwork to flow what the vq35 does stock, the rb requires major headwork to flow good as well but it wont hit vq35 numbers due to its smaller displacement. both engines where great for there time but the vq35 is a superior engine its only major downfall is the rods.
if your looking for a budget vehicle sorry to say but you would be best looking into a honda or dsm and even then dont expect past 500, something the magazines dont tell you when they show off these 600,700,800+ hp beasts is just what it costs for the vehicle to be somewhat streetable and reliable dosnt matter if its a 350,370, gtr, supra, evo, sti anything even lsx swaps have a good amount of money invested to hit these power goals
oh yah almost forgot if you do built the vq35 do at least a revup pump, iirc the hr pump should fit also but requires modifying a locating dowel on the engine
