Thanks for the info! I did a little more research on that module, and it has a lot of bad reviews...you can't customize anything with it, so like you said I would probably need to go with a different unit.jroo wrote:you may see a small bump in power for the kit because it looks like the piston will be higher compression. Not sure what stock is but they are listing close to 11 so you may also worry if it can run on premium fuel? The biggers concern for me would be the module. I saw those years ago and thought they worked but mainly on a stock engine. I thought it just doubled over the stock ecu. I dont know if it would help you on cams, headers, and internals. You would have to ask to be sure. If you go that serious, you may have to look at true stand alone to make it work.
Hey thanks for the heads up on the VQ35 engine thread...I apologize that I probably should have put this into that thread! I haven't had time to look at all the posts in that thread, but I just glanced at some and the majority of them are dealing with the 350Z VQ35DE (which isn't surprising, lol). I actually have an automatic transmission on my pathfinder, so I don't think I'll attempt to go with a Z engine. I checked that car-part.com website...cheapest engine listed was $950 (there were some that said to call for price). I got a number for a local shop here that has very good reviews that I'm going to ask and see if they would be able to source an engine and what the cost would be.4xq wrote:There is a vq35 engine thread here, you might learn some stuff over there, altho you may have to go back a few years to when these engines were the latest thing - I think a lot of performance tuning is now done on the 4.0 v6.
The later Z's used a 287 hp version of this engine - bigger valves, different cams, etc. Since you have a manual transmission, it *might* be possible to use a long block from that and hang all the necessary Pathfinder parts on it. You would probably need an aftermarket ECM. That is just a guess tho.
Check car-part.com for engine prices. Pathy engines can be had for 400.00 from the wreckers.
sigman70 wrote:Hey all...I'm in the process of pulling the engine on my 2002 Pathfinder (casualty of the power valve screw issue), and have been searching for ideas on
increasing the performance of the engine (VQ35DE)...as most of you probably know, there isn't much in the way of products available for this Pathfinder engine, but I did come across some things that I wanted to get people's opinion of. (NOTE: I do realize this is not a race car, but I just would like to see if there's anything I can do to increase the power on it)
This is an engine kit I found:
http://www.importperformanceparts.net/i ... issan.html
And another one:
http://www.rhdjapan.com/power-enterpris ... q35de.html
This is a cam I found:
http://www.4x4parts.com/i-18916837-high ... -cams.html
A performance module:
http://www.4x4parts.com/i-18980869-v-fo ... odule.html
A place that does custom headers (since I've been unable to find anywhere that has them for this engine):
http://www.stainlessheaders.com/customheaders
I already have a dual exhaust and cold air intake that I had put on before the engine seized, so I will still have those for the replacement engine. Just curious to get some opinions on all these and if anything else would be needed for them (like if I got the engine kit, are there other things that would need to be upgraded). Thanks!
Lol, no worries...I almost did the same thing when I was searching!4xq wrote:Well, for some reason I put in engine block price. Seems I have lost a powervalve screw between the ears. Gotta slow down and reread what I post.
Hey there...thanks so much for the reply! Yes, I would really be interested in hearing about how this goes! The one link I posted about the custom headers is very expensive, and I've almost pulled the trigger on these (which again I'm not sure they are actually headers or just manifolds - they mention both in their description):351cleveland wrote:If you are going to go the route headers, i am in the middle of making some doug thorley shortie headers made for a 2005-2009 pathfinder/xterra/frontier with stock magnaflow replacement cats for 2005-2009 pathfinder work on my 2003 QX4. Still waiting on my doug thorley 4.0l pathfinder b-pipes to arrive, then im taking it to A 4x4 shop to install and finish off the exhaust to fit. It should work, as i have already mated up the ports to one of my old stock manifolds, and they match up perfectly. Will update everyone when the project is finished.
