i got AEM standalone(2300 with harness), but the pulse doesnt work right. unfortunatly it would dip my torque curve at about 5-5.5k when it would switch on like Vtec. I made more bottm end torque with it on for some reason. 247whp w/o up top. I was told it is tunable but very difficultfireslave wrote:Yea, I just found that haltech one on the internet today... first one I'd even seen that controls the VVT. It totally gave me hope.
I was considering just bringing over all the 350z components that are required, but I really like the idea of the megasquirt, because it allows precise tuning for a low price. Initially, i plan on leaving the engine fairly stock... except probably a bigger exhaust because I'll have to custom fabricate that anyways. But it would be nice to be able to boost it later and have it properly tuned. I know you can buy turbo kits with various forms of engine management included, but I wont necessarily want to spend $6000 on a turbo kit when I'll probably have to make custom piping for everything anyways...
Besides, if I made a standalone N-VCT controller i bet could sell it for a profit and still appeal to the DIYers and megasquirt crew...
But yea, I know electronics on cars are scary these days... but I think I could figure this out eventually if i had an oscilloscope (which I can use, but definitely cant afford) or if i had some idea as to what the PWM values were...
If not, hopefully I can find a newish front clip with the trans. and all the electronics for 3000-4000.
is it at all feasible to use an AEM unit from some other 6cyl engine that has variable intake cam timing? repin the connector and such instead of going with the AEM universal unit or Motec, Haltech for that matter?SERVQ wrote:
Yes, but Haltech (Platinum 350Z PNP EMS) is already programmed to control them on a VQ. This ecu has been used as a wire-in for multiple VQ35 swaps into other cars, such as the S13/S14. If you need any info, I have all of it available. Contact mesr20goofus wrote:is it at all feasible to use an AEM unit from some other 6cyl engine that has variable intake cam timing? repin the connector and such instead of going with the AEM universal unit or Motec, Haltech for that matter?
I have been reading through the FSM about the cam timing and how it works, but there is no difinitive answer to what the ecu output is that makes the cam timing advance or retard, at least that i have found yet, more searching to continue.
that would be true for older cars, and some newer cars.. but deffinatly not the 350z or g35, what TS, JWT, and UpRev can do with the factory ecu is for the most part better than a stand alone.sr20goofus wrote:standalone > OEM ECU,...more tunability, on the fly changes, and more integration.
i wouldnt believe this for a hot second. a plug-n-play unit is garunteed to help increase fuel efficiency, and your power band, even on a completely stock motor. Where did you hear that standalone wont net any gains? is this a 350z specific claim? or stock motor in general claim?irax wrote:with the uprev's osiris system it changes on the fly and its way cheap compared to other ems's , but the fact of the mater is that not one stand alone out there can make at least stock power on a stock motor
using one random VQ swapped 240 as your base isnt a fair judgement. the dyno could have been out of calibration, it could have been a chassis dyno instead of a dynodynamics, or dynojet dyno, maybe he had a bad tuner, maybe the 315whp Z's your claiming were SAE corrected for perfect day at sea level, maybe it was super hot in CA when teh test was done, etc etc...irax wrote:it was 350z specific... but honestly its based on info that is a 2 years old. So basically prior the most recent update to haltech. That and seeing the few vq35de swapped 240sx's out there what what mods and what they dyno at and compaired to G's and Z's with the same mods put down more power and the only difference was tuned ecu vs stand alone. Like the issue of supper street where they pit an s13,14,15 against each other and one had a vq35de, one had a KA-T and the s15 was stock block and minor mods around a track. and the s13 with the vq had some stuff done to it and it only put out 285hp. P&P, cams, intake, exhaust, AEM. I know that G's and Z's with a tuned ecu alone put down 270 and with same mods(except ecu) as that 240 put down 315-320
these new ecu's that nissan makes are really freaking trick compaired to the older ecu's
