AcMav wrote:Is this going to be a daily driver? or a track car?
Are you removing the rear seats to reduce weight? If so are you going to weld solid the rear doors and strip the rear window mechanics and epoxy the window in place?
I Hope you're upgrading the fuel system as well (Bigger Injectors, Bigger Fuel Pump, Larger Gauge Fuel Lines). I know Kzoosho had to replace the stock fuel pump when he turboed his, I'm not sure how many Gph the stock pump can put out.
I'd just like to say I've also always heard good things about the Emanage Ultimate. Are you going to be doing the tuning or sending it off to an Import shop to tune?
Last but not least, What octane are you planning on hitting 300 hp with, 93 Octane Pump fuel? or 110 Octane race fuel? (Its fun to have two settings on your ECU tuned for both, something you should considering doing while tuning)
Goodluck Bro, I've always wanted to build my I30 but being a student I just cant finance it, and like you, I like doing things right the first time
This car will remain a daily driver for now.....maybe someday down the road a full heavy weight reduction will be in order if I find a nice daily driver (Mercedes C43 is on my mind alot these days), but when the time comes, the only things left inside the car will be 2 seats, steering wheel, shifter, gauge cluster, and other essentials and the four side windows would be replaced with a light weight plexi and AC condensor gone (but thats not happening for a while.
As for the fuel system there is no need to upgrade the fuel injectors, I forget A33 injector size (300-310cc I can't remember I think its less). but the fuel rails are good for 500+hp, injectors are good for 325-350hp, and I may mess with the FPR but thats about it. Everything else can handle the extra push. I do plan to continue using 93, hopefully I don't ping with the high compression, if I do then I should be able retard the timing a degree or two with the EU, if that doesn't work I'm SOL.
As a final note, this engine is very much up in the air, I want to really push for it but it is not cheap (not complaining it will be worth it if it works), but there is no who has gotten it to work, but in theory on PAPER it will work.....I'll say it again IN THEORY ON PAPER THIS SHOULD WORK. but if not, then I will pull the engine, drop the bottom have and throw the 3.0 internals back in and run a thicker gasket to drop compression and dropped compression means you know what...
