Car is a Maxima SE 2000 with Aut. trans.
Symptoms: Car has erratic transmission operation. Car won't shift in 3rd and 4th gear. 4000rpm at 75km/h, if you push the o/d button and take it of, the transmission slips and engine rev to cutoff. Engine seams to work properly, and idle is good. Shifts from reverse, first to second gear is smooth. But will rev up or get back to first gear without behing needed or with any additionnal throttle.
What I've done so far:
-6 months ago:
Replaced the MAF sensor after an erratic throttle response episode - this was before the transmission problems started occuring. I also cleaned the throttle body at that time and replaced air filter.
-This weekend:
-I adjusted the TPS properly, to get 500ohms closed, and 4000ohms with WOT. Operation is smooth and gradual and you increase throttle.
-Took off the tranny oil pan, took off the solenoids and cleaned everything including the debris magnets at the bottom of the pan. Made the solenoids operate with current and made them "click" properly by cleaning them with compressed air. Tested - works fine. Reinstalled.
-Took out the TCM, opened it, checked for cracks, cold soldering issues and for fried components, board is perfect from the exterior, no issue. Reinstalled.
-Took a look at the crank position sensor under the engine, near the oil pan. Took harness off (was hard to get out), inside of the connector looks clean, no debris or grease. Didn't pull the sensor off tought...
I also did a scan, found the following codes:
-P0744 Torque Converter Clutch, Solenoid Circuit Intermittent
-P0444, 0443 or similar (not sure). Evap canister problem
I erased the codes after I had worked on the car, and went for a test drive. Car still did the exact same thing. Only the EVAp code came back (haven't check that yet).
-P1446 Evap canister problem
-P0174 - too lean - bank 2 (I think this is normal as I have a small hole in the flexible part of the exhaust, just before the cat...)
What I suspect now:
-bad revolution sensor
-bad crack position sensor (don't know if it can affect the transmission operation like that tought...)
-TCM and/or ECM need a reflash / reprogram (considering I adjusted the TPS, changed MAF a while back etc...)
Let's hear what you guys think!
Thx
