GseaQ »
https://forums.nicoclub.com/gseaq-u329.html
Wed Jun 10, 2009 5:06 pm
So, the trashed upper links have been replaced, along with steering rack bushings, tension rod bushings, front rotors, pads and calipers. Every component replaced so far has made some improvement - slightly tighter feel to the suspension and steering each time, BUT the core vibration problem is STILL there, especially bad with light to moderate braking from 75 mph down to 60 mph. Looking at the suspension design, the remaining wear components are, tie rod ends, ball joints (incorporated into the lower control arms?) stabilizer bar bushings and kingpin bearings (kingpins, too?).
The tie rod ends and ball joints are tight. The stabilizer bushings are worn and there is visible play in the driver's side kingpin/bearings. I've ordered the kingpin bearings (both sides) from IOS. Hopefully that'll kill the remaining vibration.
I'll let you know what happens next.
Modified by GseaQ at 8:18 PM 6/10/2009
Modified by GseaQ at 8:20 PM 6/10/2009
