Sorry to bump an old thread guys, but I need to fix some incorrect information in this thread... especially considering it is the first to come up in Google when you search for VG34E.
I will first start by saying that I have not done one of these yet but am planning on it and this info is based off of what I have been able to gather so far.
VG34E:- VG33E with a 1.5 mm overbore (~.059)- VH45DE pistons 90-96 - they need to have valve reliefs cut into the tops for the VG's head design. Bring your stock pistons in to your machinist and he should be able to figure it out from there- Cams - if you're looking for that 250 hp number floating around you're going to need some cams and possibly some head/port work. Personally I'd go with a custom grind from a company like Isky as most VG cams will be aimed more toward being turbo cams while companies like Isky can do a custom grind based on exactly what you want.- Stock rods with a custom small end bushing - VH45 pin is supposed to be 1mm larger in diameter
This should get you the VG34 setup with a ~9.7:1 compression ratio. The compression ratio based on stuff I've seen online though the claim on Zbum's site says 10.2:1... I don't believe that is correct though since the VG33 heads are supposed to have a larger combustion chamber for one... I could be wrong though.
Since this is showing up on Google search I'm going to go ahead and throw in ideas for VG34E swaps like into the Z31 300ZX or even the 3rd gen Maxima:
To make the swap easier in vehicles with the VG30E... simply swap the crank from the VG30 to the VG33, then go with the VH45 pistons. This will allow you to then use the oil pump, oil pickup tube, oil pan, timing belt gears (cam gears needed as well), crank pulley, and the accessories and their brackets. The accessories are the big reason to do the crank swap, it will make the swap a lot easier. From there just go ahead and also swap all of the sensors and all external bits like intake and exhaust manifolds, motor mounts, etc. and that should allow you drop the engine right in.
Please note that if you do a swap like that you will need to get some bits for the standard VG30E oil filter location. The VG33 has a plate that covers the standard filter spot and I believe the check valve needs to be installed there:
http://www.courtesyparts.com/M..._Code=
I haven't seen it mentioned, even though it should really be a given since you're messing with the internals... but, regardless of what route you take, I would get the rotating assembly balanced. Most definitely if going with a VG30E crank but even swapping pistons changes the balance and I wouldn't trust revving the engine very high without a good balance. You may not notice it but your bearings definitely will.
Now, on to some corrections!
SnowSurfLax wrote:I don't know if you want to turbo it. You'd have to get a stronger crank made as the VG crank is only cast. Looks like a really $$$$$$ project at that point.
Definitely, definitely, definitely... NOT the case. The crank is actually "nodular" iron which they say generally puts the strength between cast and forged... however, no one that I know of to this date has EVER broke a "cast" VG crank from too much power. That 350 hp limit you might find online around various places is no where near correct. There are many pushing 300+ whp, others pushing 400+ whp, and even some making 500+. I hear there has even been a VG30 pushed to 700 hp on stock internals, though I bet the pistons were very short lived. The pistons will be the absolute weakest link in any stock VG.
Quote »Yeah, I've heard that the rods from the DETT are stonger and take twice the amount of torque that the stock VG33E rods take.[/quote]Unless Nissan used substantially smaller rods in the VG33 than they did in the VG30E, I would say this is likely incorrect. They will be forged and, if like the VG30E rods, only marginally smaller than DETT rods. If rod strength is of any concern, I would probably just skip past the DETT rods and go straight to aftermarket forged rods with ARP or similar fasteners. Not only do you get more strength, of course, but you also usually get a good reduction of weight which is very important. The stock rods will be plenty for most daily driven vehicles looking for a very decent increase in power.
