AnglerfisH »
https://forums.nicoclub.com/anglerfish-u11439.html
Wed Dec 24, 2003 2:10 pm
The VG series is SOHC or DOHC depending on model. The VG30E (seen in the Maxima GXE 2nd and 3rd gen as well as several nissan trucks) is SOHC and puts out 160hp in base form. The VG30DETT is used in the 300ZX TT. It is DOHC and puts out anywhere from 280-300hp. Again Iron block and aluminum head. The VG30ET was used in the Z31 Turbo and was 205hp. It was the same block and head configuration as the rest of the VG series, timing belt as well. The VQ series is DOHC period. It is anywhere from 190-222hp (VQ30DE-VQ30DE-K) to 255-287hp (VQ35DE). They are both aluminum block with an aluminum head. They have a timing chain instead of a belt. It is used in the Maxima, G35 coupe and Sedan, as well as the 350Z. Both engines have their strengths and weaknesses.
