It was a JUN built VG30DETT and the record still holds. http://www.junauto.co.jp/democar/index.html?enMiiLaNo wrote:
2nd the speed land record is actually a Z.... I think it did something as 419km/h (260mph) the one on bonneville speed trial?
yo,seen escort racings z32 i think its in the 7's not sure but theres a holden in ozzy thats vg powerd and its in the 8's(street legal). its not so much the motor but the chassis.if a top american builder puts one together its gonna be fast no matter what engine it has.the reason the inlines perform better is the high mounts.there are mor 1000hp vg's around than 1000hp low mount turbo rb's and 2j's if any.aidanair wrote:why is it if the vg and rb and 2j are all forged and all built to hold extreme power, why does the 2j and rb outperform the vg when fully blown.. the fastest 300zx in the world runs like. 9? the fastest supra 6 speed does 8.6, and the fastest auto is in the 6's. rb its about 8.
well as far as speed, my supra was faster, however thats only because I had it modified and my Z wasnt, although since my Z was stock it actually did very well against the supra. of the line, they were fairly even until hit third the supras rear is in my face however stock turbos on both and same stage of upgrades, I like the Z better since its turbos are not sequential and boost instead at the same time, but they actually both were equally good, although the Z handled much better IMO.aidanair wrote:miilano being that you have both a supra tt and a 300zxtt mind sharing some of the pros and cons of each and which you prefer? thanks man
since when was the vg forged from the factory? NEVER! stock pistons are cast. Not to mention another reason the vg wont ever make as much power as them is on the head(s). CFM flow for all motors, vg is by far the smallest. Motor wasnt built for high rpm and huge turbos, more for mid range turbos with low end grunt. RB was designed for higher rpm usage, and ports are more designed for high rpm racing.aidanair wrote:why is it if the vg and rb and 2j are all forged and all built to hold extreme power, why does the 2j and rb outperform the vg when fully blown.. the fastest 300zx in the world runs like. 9? the fastest supra 6 speed does 8.6, and the fastest auto is in the 6's. rb its about 8.
I'm not sure what you're trying to compare here exactly. If you're looking at a 800hp VG vs a 800hp 2JZ I guess what you're saying makes sense, but the VG is going to be nearly maxed out on it's build. 2JZ's are hitting 1200rwhp+ all day long while we have like 2 VG30 Z32's pushing 1,000.mtcookson wrote:Drag racing... that's definitely a tough one as both engines can easily be built to perform equally as well. The most important thing though... it just comes down to money. If you have enough money you can make nearly any engine make a ton of power. If I had to choose between the 2JZ and VG for drag racing... the Nissan enthusiast in me would go for the VG but if I just so happened to get a 2JZ or were given one I definitely would not turn down the opportunity to use it.
Maxed? Hardly. You aren't going to touch low, low 7 second 1/4 mile runs with 1,000 hp. I know for sure Jorge Lazcano was making more than 1,000 hp to make a 7.09 second pass. That's why I said its all about money... they definitely had a ton of money in that car just like you would have in a 1200+ whp 2JZ.movin_up wrote:I'm not sure what you're trying to compare here exactly. If you're looking at a 800hp VG vs a 800hp 2JZ I guess what you're saying makes sense, but the VG is going to be nearly maxed out on it's build. 2JZ's are hitting 1200rwhp+ all day long while we have like 2 VG30 Z32's pushing 1,000.
Maxed out wasn't what I was looking for but I was typing that quickly on my phone, lol. My points was, you generally don't see a Z32 making more than 800 wheel that's not owned by a race team or Z1 Motorsports. I'm not saying there's not others out there and I think I have actually heard of another, but Russell's car is the only street driven 1,000+ car that I know of. The rest are running $12,000 stroker kits being trailered to the track.mtcookson wrote:
I'm not saying the 2JZ is a bad engine, not by any means. They are proven over, and over, and over again to be a monster of an engine and I believe are much better engines than the RB26 when power potential is of concern.
In the end... if I were to build up a drag car like that, I'd personally use the VH45 instead.
The VQ is definitely still up for consideration, but I don't really know much about it and I'm currently stuck on the idea of how easy the RB would be to work on.mtcookson wrote:Definitely... cornering is where its at. If cornering capability is what you're looking for I'd personally stay with the VG... or... maybe... try out a VQ swap. Still great potential, especially if you use the 3.5 for the extra displacement. The real benefit though... it will be quite a bit lighter potentially helping out cornering capability much more. That's what was done to the JGTC R34 Skyline... they dropped the RB26 in favor of the VQ30 (can't remember if they ran a single or twin turbo setup... twins I believe). The VQ was so much lighter and compact that it greatly improved the handling characteristics of the car making it faster than the RB26 equipped R34.
