niterider93 wrote:you have air pockets going to the heater core thats why its taking that long for heat to come out you need to bleed the system good . also you have have to make sure the coolant is 50/50 because if ts not and theres not enough water mixture coolant dosent evaporate and make heat its water in the mixture that makes the heat .
In theory the air pockets would make sense, except if that were the case, I would also see fluctuations in the engine heat wouldn't I? The system has been opened up 2 times over the past 2 weeks also with the changing of thermostat, blowing out of heater core. Also, if it were air pockets, would not the time needed to get actual heat be different each time rather then the 15 to 20 min after temp gage shows normal operating temp? Its these things that are leading me to believe 1 of 2 things, but I am not familiar with these systems, so I am not sure.
1- The temp control switch on my climate control is not operating correctly and even though I have it in the hot position, (all the way to right) it is not allowing the valve to open all the way to let the hot water into the heater core, thus it taking longer for heater core to heat up then it should.
2- The temp control valve itself is not operating correctly, causing same problem as above.
Anybody think I am thinking on right path? If so, how do I diagnose to be sure? Where is the actual valve that controls water flow to heater core?
