Hey guys,
Your seriously my last hope.
My Fiance has an '09 Versa Hatch that could use a battery replacement.. So we went ahead and grabbed one from the local Costco only to realize that the battery tie-down actually grabs the little molded "feet" of the OEM battery...
There is no "over-the-top" design and due to this we can't mount the Costco battery correctly because not only does it not have the little molded bottoms to allow the clamp to press down on it and hold it in place.. but it's also about 2.5" shallower than the OEM battery giving it that much extra room to slide forward and backwards.. in addition to not even being close to the clamping bracket anymore..
I've called up every autozone/costcto/pepboys in the area and they all say I have the correct replacement battery (51R) but can't give any advice on mounting..
I've called up every Nissan dealership in the area and they all say I need to use the OEM battery, and have no clue about the mounting either.. (one of them told me they ALL are over-the-top type mounting...)
I did a little searching on here for "battery" and not much really came up, so I'm praying one of you can give me some input on what in the world is going on..
I'm especially confused because when I go to Courtesy Nissan none of the diagrams really match her mounting style..
http://www.courtesyparts.com/versa-hatc ... _6418.html
The bracket that is holding the battery down is the small piece in the second diagram in the separate box with "AT/MT" at the top.. but there are no over-the-top mounts there like there are in 90% of the diagrams on courtesy parts..
That piece is actually holding the battery's "feet" at the front of the battery. (mounted under the small strip fuse box that has the horn and everything on it)
I'm really at a loss with this guys, any information at all is really appreciated.
Thanks!
