Can anyone tell me if the VE30DE has any bottlenecks in the intake and or heads that would prevent them from 500whp + ? I know the rotating assembly is the same as VG30de(tt) and it would need lower compression pistons and a stand alone is probably not a bad idea. So there's 25+ psi. Will this motor choke itself out before that? Boost will only build heat if there's restrictions and I need to know where that point is at on this motor. I'm talking about dead stock no ported TB's or heads. I've looked everywhere to no avail. Hope Someone can help.
Modified by ghost port at 3:15 PM 1/31/2010
