kerrton wrote:SenorPayne, we're short on details about the fix for this problem. Did you have your problem corrected by the dealer? If so, what was the fix?
Ironically, I want my VDC, Slip and ABS lights back!
While doing a test drive before I took over my 2008 SL AWD from previous owner the VDC, Slip, AWD and ABS warning lights came on. Otherwise the vehicle drove smoothly and everything was just perfect. We agreed with the guy that I would take the vehicle if he's able to get rid of the warning lights. He sent it to a local dealer who got rid of the warning lights but I never bothered to check what he actually diagnosed. Very stupid of me, when I saw the warning lights were no more I paid off the guy and drove my Rogue to my station, close to 500km away, without doing any further checks, only to realize that when the ingition key is turned in ACC mode all these lights do not appear at all! So I have no means of telling if all these are functioning. However, I hear the click sound when I engage the AWD manually. I sent the vehicle to a local Nissan dealer who says everything is functioning properly but can't tell what the other mechanic did. Strangely No Error codes - at least that's what he claims
Is it possible the smart guy made the first mechanic remove the LED on the dash board or there are fuses that could have been removed just to take my money? When I took a closer look I saw that one of the tyres is of different brand. Is it possible this was what confused the VDC, ABS to give the warning lights? The low tire pressure indicator appears faintly. (mileage - 31K Km). Any ideas? I'm not very bright with automobils
