Uh ... yeah.woo wrote:Now "VDC OFF" "SLIP" and "Brake" lit up on my dashboard...is this mean I gotta get the brakes done ASAP?
zerothread?id=391989woo wrote:Ever since two days ago "VDC OFF" and "SLIP" light came on while I was driving in the morning on my way to work and it's been bothering me all day and nothing came on after work on my way home...and surprisingly it was doing the samething again in the morning and nothing at night time...I tried to turn the switch to "ON" but the light still there so there's no way I can't turn those indicators off. Anyone else had this issue??
take your foot off the brake pedal.papaupa212 wrote:i have the same problem vdc and slip on at the same time..also my car feels like the brake got stock on all 4 wheel. what can i do about that????
If you replaced the camshaft sensor(s), maybe you need to replace the crankshaft sensor(s), too. The right search might help clear that up for you, but to summarize assuming I remember correctly, they are the same part and some of the codes can be confusing.Xoxopromesa wrote:Hey guys I have a 06 m45 and Im bugged about the VDC and SLIP light constantly turning on, on me and not being able to clear it. ALSO my car would stall and turn off in the middle of my drive as if the batter went out): Mind you not I work at a nissan dealership so I get all the help i need. Got a diagnostic and I was told 9/10 times its the Camshaft sensors that cause the stalling so I went ahead and replaced those. NOT THE PROBLEM at least for me. I figured it was the solenoid so I replaced my vias control solenoid. Took it on a test drive last night. Sure enough the VDC and SLIP lights turned back on and my car died on me smh it's not my fuel pump either so I'm just utterly confused now
The00Dustin wrote:If you replaced the camshaft sensor(s), maybe you need to replace the crankshaft sensor(s), too. The right search might help clear that up for you, but to summarize assuming I remember correctly, they are the same part and some of the codes can be confusing.Xoxopromesa wrote:Hey guys I have a 06 m45 and Im bugged about the VDC and SLIP light constantly turning on, on me and not being able to clear it. ALSO my car would stall and turn off in the middle of my drive as if the batter went out): Mind you not I work at a nissan dealership so I get all the help i need. Got a diagnostic and I was told 9/10 times its the Camshaft sensors that cause the stalling so I went ahead and replaced those. NOT THE PROBLEM at least for me. I figured it was the solenoid so I replaced my vias control solenoid. Took it on a test drive last night. Sure enough the VDC and SLIP lights turned back on and my car died on me smh it's not my fuel pump either so I'm just utterly confused now
