Hello All,
New here tonight. Greatfull for this site ! Already I can see tons of information, service manual and information available. Wondering if anyone can point me in the right direction. I have a 2008 G35X Sedan. I have to replace a front brake band solenoid in the valve body. It isnt working resistance is 0 ohms plus the code came up as it as well p1757. I had to do all this I should at this point add; not because im a hack, but I do not have the funds right now to pay a mechanic.
So I have the valve body out of car, position 4 solenoid is bad. But I knew it could also be a problem inside the tcm a broken pin. I opened it up is all good no contamination isssues. In getting at the tcm though, I know some of the check balls moved out of their position before opening it up. So now at this point Im thinking im over my head to put this thing back together AS FAR AS EVERY CHECK BALL IN EVERY SPOT IT NEEDS TO BE IN EVERY WORMHOLE and as to get it done properly so i dont damage my trans.
The car was in limp mode with the p1757 comin up twice on a crappy scan tool. I still need to find a replacment front brake solenoid as im hoping I can REPLACE SOLENOID AND PAN GASKET AND NEW FLUID AND BE GOOD WITHOUT HAVING TO FLASH ANYTHING ? ANYONE KNOW ? Also anyone know of a DETAILED SCHEMATIC OF THE CHECK BALL AND SPRING LOCATIONS IN WORMHOLES ? Or anyone I could send this thing to who would put it back together for me right for a better price than what these trans shops charge? I dont even need the shift kit just someone to put it baack together lol fml ...Im not working right now is my biggest issue..
Love this car so much though !! They really killed every other brand out there with that 3.5 l v6 , I think. You would definatley have to get a major gas gusslin audi or bmw to match its power thats for sure !! Just wish I got a mt now ...
Thanks for your time , James
