look around a little. u can download them for freeidahotuner wrote:were will i find that. i guess i will have to search.
it wouldn't have worked that way. i tried it. first off there is no wave washer.the aluminum ring has to go on top, because the hole on the top plate hole isnt small enough to hold the shifter and every thing in. i can take it apart to show you.the aluminum ring acts as a washer. from what i can tell. and if it was on the bottem everthing would not be held in place.mrgreeneyes wrote:um, not to be a negative nancy, but the aluminum collar is supposed to go UNDER the stock lower white ring, spacing the shifter HIGHER than stock, allowing the reduction in shifter movement.
so from the bottom, up:
aluminum spacerwave washerstock white lower ball pivot-y plastic ringshifter ballnew white top ball pivot-y plastic ringthen the weird-arse top plate w/ retainers.
i used to have one of these and this is the proper way to do it. your way will leave the small shifter bushing about .5" too far into the trans, not letting the bushing interface with the trans fork piece, but rather letting the "wrist" of your lever make the contact.
yea i will pull it apart and see. what i can do. i just dont see how it will work doing it that way. but i will try it again.mrgreeneyes wrote:i had the exact same one so i KNOW it works the way i said... and the stock shifter has a wave washer.. just tryin to help ya out so when you go to make your first boosted shift, your lever doesnt snap/rattle like a mofo.
its a work in progress. i am going to fix that part.niemczykj wrote:WOAH, the metal bushing goes underneath!... u put that in first, then the plastic yellow piece with the metal cylinders, then the yellow plastic washer/bushing.
the metal goes on the bottom to make up for the higher position of the metal ball on the short throw.
