placham »
https://forums.nicoclub.com/placham-u38577.html
Mon Jan 30, 2012 1:49 pm
Use all the electronics from Rb20 on RB25 with Rb20 harness and ECU, like TPS, CAS, Coils, ignitor, Knock, water temp,O2, $hit its basic. Use all and as many electronic parts as you can, its common sense.
You might have a issue with injectors Rb20 top feed, Rb25 side feed, and their different impedance I think too, if connector plugs fit, otherwise might have to go with Rb26 injectors and fuel rail upgrade.
p.s. you can run Rb26 harness&ecu with some mods (MAf, O2) on Rb20.....
Im sure you'll get same answer on zilvia
