Dedicated to the G37 Convertible. This forum is for convertible-only content that is NOT covered in the other G-Series forums.
Using Iphone / Ipod with your vert or even G37
Postby cmesurf » Wed Nov 23, 2011 2:59 pm
Here's the info some vert owners have been searching for a while- how to charge and use iphone thru OEM adapter cable that come with car. The thread if you search shows up but can't post to it.
:dblthumb: Use Scosche passPORT Charging Adapter for iPod & iPhone between the OEM cable and the Iphone/ipod .... :bowrofl:
The adapter connect to the OEM cable and other side to your "I" device.
Good Luck
CMESURF
cmesurf
Car: Infinitis, 03 g35 coupe/ 07 g35 sedan/ 03 fx35/ 05 FX45/09 G-vert
Re: Using Iphone / Ipod with your vert or even G37
Postby Fezzik » Thu Nov 24, 2011 1:37 am
Just a heads up to Vert owners or G37 in general. this only pertains to ALL g37s made 2009 and before. 2010 model used a direct USB cable (you use your cable supplied with the iphone)
Current Car
1.) 2010 Infiniti G37 Convertible 6MT White w/ black interior
GTM Stage 1 Supercharger
GTM Oil cooler with Thermostat
430hp/340tq
2.) 2008 M35x
3.) 2013 JX35
Previous cars
1.) 2002 Silver Maxima SE 6 speed
2.) 2005 Xterra
3.) 2000 Maxima SE
4.) 1993 Maxima 4DSC
Fezzik
Car: 2010 G37 Vert w/ stage 1 GTM supercharger
Postby cmesurf » Thu Nov 24, 2011 6:59 am
Fezzik wrote:Just a heads up to Vert owners or G37 in general. this only pertains to ALL g37s made 2009 and before. 2010 model used a direct USB cable (you use your cable supplied with the iphone)
The above info is correct. Thanks :bigthumb:
cmesurf
Postby audtatious » Sat Nov 26, 2011 3:18 pm
2008 G37s Coupe | Invidia Gemini CBE + HFC's | Cobb Stage 2+ | GTspec FSTB | BC Coilovers | Hotchkis Sway bars |
Eibach Camber kits | R2C Intakes | TBW engine cover | 20" ForgeStar F14's | 6000k HID + Fogs
2007 G35s Sedan | 20% tint | 6000k HID's | LED's | G37 19" Wheels
audtatious
Car: 2008 G37s Coupe - 2007 G35s Sedan
Postby cmesurf » Sat Nov 26, 2011 3:25 pm
audtatious wrote:http://www.infinitig37.com/TSB/ITB11-059.pdf
^^^ newer TSB
Good Info for All Infiniti vehicles equipped with a USB Interface. :bigthumb:
Thanks
cmesurf
Postby audtatious » Sun Nov 27, 2011 10:12 am
There is another TSB concerning bluetooth for those who were not aware:
http://www.infinitig37.com/TSB/ITB11-040b.pdf
audtatious
Return to G37 Convertible Forum
