tater02 »
https://forums.nicoclub.com/tater02-u168070.html
Fri Mar 23, 2012 2:26 pm
I am having a vibration issue when I turn my wheel left. No vibration when I turn the wheel right.
I changed:
-wheel bearing/hub passenger front <1000 miles
-passenger rear wheel bearing <1000 miles
-passenger cv axle (DSS axle) <10000 miles
-inner/outer tie rods both sides <5000 miles
-alignment was done recently
-changed winter to summer tires(still the same issue)
-ES motor/sway bar bushing
-new 6th gen front brakes slotted and crossed drilled that replaced cross/slotted 5.5 brakes(still the same issue) <1000 miles
-illmuninas and H&R spring >40000 miles
I replaced the 6th gen brakes recently and i noticed that the right caliper brake pads were worn more then the left. Maybe the brake lines have dirt in them and need replaced because the caliper are greased and moved freely.
My car has 100,000 miles and still the same driver axle and wheelbearing. Also, I do have a little leak from the passenger side transmission seal, but extremely little. Any ideas what the problem might be?
Thanks,
Andrew
tater02 on Mon Mar 26, 2012 5:38 am, edited 1 time in total.
