Underbody Side Puddle (courtesy) Light Installation DIY
moedawg140
Car: 06 M35 S (Adv. Tech)
LI Quad
G37 BBK with H&R DRS
(15mm F, 10mm R)
Focal 165KRX2 (F)
Infinity Kappa 63.9i (R)
Alpine Type-X 10"
JL HD900/5 (sub chnl.)
RF CPCD10-03
Morimoto 4,300K H11
Underbody Side Puddle (courtesy) Light Installation DIY:
When I saw puddle (courtesy) lights on several threads on this site, I knew I wanted to have those on my car as well, so I could have a little more light when unlocking/opening the door at night. The coolness factor is definitely up there in my opinion, and when done right, looks stock. You won’t be able to see the actual strip lights unless you bend all of the way down and look underneath.
You’ll need:
-LED strip lights of your choice: I ordered 2 of the 5,000K 48-inch 72 LED strip light set from vleds.com
http://www.v-leds.com/Strip-Lights-LED/ ... 46996.html
If the strip lights are out of stock, you can purchase another color/length, or keep checking back to see if they have the ones you want in stock.
-Car Ramp
-Power Drill with different widths drill bits
-A thin metal apparatus (like a straight hangar) or use fish tape.
-Electrical tape
-Thin hard object like a spatula
-3M Strip Caulk (or equivalent)
-Snips/sharp scissors
-Zip ties
-Rubbing alcohol
-Speaker wire - ~1ft (You’ll need long enough to make it from the end of the strip light wires to the footwell light wires)
-Wire stripper – something like this one:
-Soldering gun or iron with flux – something like this one:
Use car ramp and make a front tire go up it.
Take off the kick plate carefully, using a thin hard object like a spatula (pops off) - shown here:
Take tabs off underneath the kickplate (you only need the front exposed) so the carpet is pulled back and the frame is exposed.
Use the size drill bit that can be used to get the thin metal apparatus that you will use to “thread” the strip light wire through the bottom and top holes you will drill.
Drill as straight as possible a hole from the top to the bottom of the car frame as shown here:
Image Image
Have a long enough drill bit to drill the top and bottom of the car frame at the same time so it is infinitely easier to fish the strip light wire through.
Important side note: Make sure to take care and not have the drill bit get loose and go inside of the top hole or you will have to use some thin metal object with strip caulk at the end of it to get the drill bit out (that is what I had to use when a bit got loose and fell in the top hole, causing the bit to get stuck in the car frame). Not fun at all.
Cut off the strip lights contact (the rectangular piece shown below)
so the wire is now showing. You will need the piece off so you can soldier the wire leads to the footwell light wire leads. It should look like this:
Wrap some electrical tape around the strip light wire end and a thin metal apparatus.
Fish/thread the two taped pieces through the bottom of the car to the top of the drilled holes. Pull it through and then take off the tape from the thin metal apparatus.
Use of a friend is nice, so you can fish the taped pieces through the bottom of the car and your friend can look on the top for when the pieces are at the hole so your friend can pull it up.
Use enough 3M Strip Caulk to fill in the holes you drilled as shown here:
Image Image
Use rubbing alcohol to clean the underbody of the car so the tape backing of the strip lights will bond better. Shown here:
Take off tape backing of strip lights and carefully place the lights from the front to the back of the car. I have it so it is a 3ft strip for the front door, and 1ft for the back door, hence was the reason why I purchased a 4ft strip. Shown here:
Image Image Image Image Image Image
Once that’s done, go inside the car and take off footwell light cover (pops right off). Unplug footwell light plug, shown here:
As you see, you also need to take off part of rubber shielding to footwell light wire to expose the wires inside. Use some snips/sharp scissors as shown here:
Important side note: Make sure that you know the footwell lights are activated when testing the wires/lights to solder (the interior lights turn off ~10 minutes of the doors being open). Just close all car doors and open to reactivate the footwell light operation if you notice that the interior lights are off.
Strip end of speaker wires with wire stripper:
Strip the end of the strip light wires with wire stripper the same way.
Solder the bare strip light wires to the stripped ends of the speaker wires. Put electrical tape over the solder. Shown here:
Strip the other end of the speaker wire housing and part of the footwell light housing so the wires are bare as shown here:
Before soldering the other end of the speaker wires after exposing them, wrap them around the footwell light bare wires with your fingers first and see if the strip light turns on (note the red arrows – you’ll be connecting so the wires meet). If they don’t turn on, change the wires to the other configuration and see if they light up. Once they light up, they will look like this:
Image Image
Solder the connection and put electrical tape over it.
Zip tie up the wires so they aren’t seen once you put on the kick plate as shown here:
Put the footwell light plug back on footwell light cover, put cover back on.
Put tabs under kick plate back on, and put kick plate back on.
Roll your car down the car ramp and roll up the other side so you can install the strip lights on the other side.
At night they look like this:
Image Image Image Image Image Image Image
Marvel at your creation and receive oohs and ahhs from the peanut gallery when unlocking or opening your doors at night.
TDot
Car: 2008 M35X, Lakeshore Slate/Tan
Great write up. Im stillon the fence with doing this. I think if I do this though I'm going to attach a switch to turn off this attention grabber in less than desireable areas that I may pullup in.
GenericM35
Car: 2006 M35X
TDot wrote:Great write up. Im stillon the fence with doing this. I think if I do this though I'm going to attach a switch to turn off this attention grabber in less than desireable areas that I may pullup in.
In Toronto? Really? If you lived here in Chicago, I would see the need...but Toronto? That place is incredibly safe.
Edit: I see you're in NY. Your username (TDot) confused me :crazy:
TXT
Car: 2006 M45 Sport
If I were to do this, I would get some lights that aren't as bright. I believe the MCD scale is used to determine brightness?
Are your puddle lights that bright? Or does your camera make them brighter than they are. I would get something way more subtle.
In my previous car (99 TL), I put lights on the outer door handles and tapped it into my dome light. Same way some Audi's have. Every time I unlocked the car with Key FOB, they would turn on. Unfortunately, that can't be done in this car because of the design of the handles.
Nice write up.
moedawg140
LI Quad
(15mm F, 10mm R)
Focal 165KRX2 (F)
Alpine Type-X 10"
RF CPCD10-03
Morimoto 4,300K H11
Thanks! You can install a switch if you want, but in my opinion, the lights don't scream for attention, it just brings a smile to the faces of most people who do see it.
TXT wrote:If I were to do this, I would get some lights that aren't as bright. I believe the MCD scale is used to determine brightness?
Nice write up.
The puddle lights are bright, but the color matches every other light component I have, so it doesn't look out of place. The camera does a good job of accentuating the light output. I will tell you that I was afraid about the potential brightness as well, but bit the bullet and did the install. No one has told me the lights were too bright, and my friend (who is more on the conservative side) actually told me I should put more puddle (courtesy) lights - on the front and back of the car!
I love how the M37/M56's car's door handles have LED lights that illuminate when you walk up to the car (no unlocking of car needed), but didn't want to go through the trouble of trying to fabricate an install like that on my 2006 M. And thanks for the compliment.
GQM45s
Car: 2008 Infiniti M45 Sport Tech Pkg, Advance Tech Pkg, Mobile Entertainment Pkg
I was considering adding door handle courtesy lights, I wonder how hard it would be to do something like that, or if possible to even try to swap door handles... would be a nice try or attempt
GQM45s
oh BTW, how are these in not so great weather? ie ( rain, snow, desert storm... haha) i was just wondering about that as I live in Oklahoma and well we are never too sure about our weather
cruzad3r
Car: 2006 Infiniti M35x fully loaded
too fast toooo furious for me... but great write up nevertheless. i agreed, deffy need a switch for less desireable location.
how long is the installation?
Ilya
Adding this to the FAQ.
I may do something similar to this as well, eventually, but only have it activated with the indoor lights (as a courtesy light of sorts).
So, like, approaching car in the dark...hit unlock and these bad boys come on.
moedawg140
LI Quad
(15mm F, 10mm R)
Focal 165KRX2 (F)
Alpine Type-X 10"
RF CPCD10-03
Morimoto 4,300K H11
GQM45s wrote:I was considering adding door handle courtesy lights, I wonder how hard it would be to do something like that, or if possible to even try to swap door handles... would be a nice try or attempt
It would be pretty tough, considering the M37/M56 handles light up as your are walking up to the car, and the M35/M45 keyless system doesn't have that option (to light up handles or anything else upon walking near the car). You could definitely make the fabricated/swapped door handles light up if you manually unlock the car, but in my opinion that defeats the purpose of it being able to light up automatically.
GQM45s wrote:oh BTW, how are these in not so great weather? ie ( rain, snow, desert storm... haha) i was just wondering about that as I live in Oklahoma and well we are never too sure about our weather
I'm not too sure, because I live in So Cal, and it hasn't rained and there hasn't been any adverse weather over here since installing the lights. Having a clean underbody where installing the lights, coupled with the 3M adhesive backing should aide well in keeping the lights in check. The strip lights are very light (weight) as well, so it will be winning the endless wrestling match with gravity.
cruzad3r wrote:too fast toooo furious for me... but great write up nevertheless. i agreed, deffy need a switch for less desireable location.
Beauty is in the eye of the beholder - I welcome your opinion. :) Thanks for the compliment. Installation should take, if using 2 people, around 2 hours. If you are doing it by yourself, add a little more time. It took around 15 minutes just to get the dropped drill bit out of the car frame.
IlyaKol wrote:Adding this to the FAQ.
This is exactly how it works. Since I am having the lights connected to the footwell lights, it works as such: Whenever the door is unlocked with the unlock button on the key FOB or door handle button, the puddle (courtesy) lights come on. When you turn your car off, the puddle (courtesy) lights will turn on - they will turn off after several seconds if no car door has been opened. Regardless if the DOOR/OFF lights toggle switch is on DOOR or OFF and you open the door, the puddle (courtesy) lights come on.
Ilya
Do your lights fade in and out like the overhead lights? That's my plan eventually if I go through with this. Would be a nice touch.
As for the lights, for those wondering, you can also google waterproof strips of LEDs like this (not sure if VLeds are waterproof as I just skimmed this thread).
I ran a small 6" section of such LEDs in my license plate on my old 99 Maxima. Looked great and never went out because they were encased in protective see through plastic or what not.
Sorry to hijack lol. Just giving slightly other options for those looking to do this.
moedawg140
LI Quad
(15mm F, 10mm R)
Focal 165KRX2 (F)
Alpine Type-X 10"
RF CPCD10-03
Morimoto 4,300K H11
The lights do fade in and out, but the fade in is around half a second, and the fade out is around 2 seconds, then turns completely off. It is definitely a nice touch when you see it in person.
These particular vleds.com strip lights are water resistant and OK for exterior use. All of the internal components are sealed to keep moisture out.
No worries on hijacking, I like to see any suggestions that I may not have thought of (or haven't had the need to use).
Ilya
In that case, good work sir.
moedawg140
LI Quad
(15mm F, 10mm R)
Focal 165KRX2 (F)
Alpine Type-X 10"
RF CPCD10-03
Morimoto 4,300K H11
Thanks Ilya, I appreciate it.
CPJ LB
Car: 12 G37X Sedan- stealthy modded
14 Altima 2.5
08 Tahoe
06 M35 S (gone)
14 Versa 4dr (gone)
....good write up...
....I'm planning to do this to my M -- when I had my E Class, this was a cool mod to do (BRABUS tuning made their cars with puddle lights that were spaced apart and turned on and off when locking/unlocking the car. you can also wire it so the lights fade when shutting off....wired to the dome lights....
here's a pix I found of another forum mbr
moedawg140
LI Quad
(15mm F, 10mm R)
Focal 165KRX2 (F)
Alpine Type-X 10"
RF CPCD10-03
Morimoto 4,300K H11
Thank you CPJ. That definitely looks like a snazzy Mercedes mod to do. Several months ago, I saw a GL class Mercedes SUV with the spaced puddle light setup.
Finiamh
Car: 2007 g35 journey
Hello
Did you wire the back(1ft) and front door(4ft) wires together?
cruzad3r
so after 5 years, i have to say i'm growing on this mod. maybe because I see it more often now. Kudos to the innovation and genius that done this mod. :dblthumb:
moedawg140
LI Quad
(15mm F, 10mm R)
Focal 165KRX2 (F)
Alpine Type-X 10"
RF CPCD10-03
Morimoto 4,300K H11
Finiamh wrote:Hello
Footwell wiring - please read and follow the review for directions.
cruzad3r wrote:so after 5 years, i have to say i'm growing on this mod. maybe because I see it more often now. Kudos to the innovation and genius that done this mod. :dblthumb:
It's been a while (years I believe) since I've posted on this forum) - I definitely remember your username, hope all is well! The puddle lights are still doing well. There was one instance where I had a wire un-solder, so I had my friend help me solder it back up and all is great!
On another note, my M35 hit 200,000 miles last week, and even though my car works correctly, I have lifter issues. It will basically cost the same to fix it compared to if I just replace the motor. If anyone has any other suggestions where I won't have to pay an uber load to fix the issue, please let me know (I've tried Slick 40-type treatments, different oil brands and viscosities, etcetera).
cruzad3r
you're masking the issue instead of fixing it. i just swapped my engine, bill came out around 3.5k. the up side is 60K miles engine with another one as a spare along with new cats and misc. parts.
if you're thinking of dumping it, then ride till it dies. if you're thinking of keeping it then invest. for me, i'm going to have another 3 years with the car so that's 1.2k per year which is less than paying for a newer car.
as for the mod, have you tried daisy chain the VLEDs together? also interested in hearing if you have any other issues with the mod.
moedawg140
LI Quad
(15mm F, 10mm R)
Focal 165KRX2 (F)
Alpine Type-X 10"
RF CPCD10-03
Morimoto 4,300K H11
cruzad3r wrote:you're masking the issue instead of fixing it. i just swapped my engine, bill came out around 3.5k. the up side is 60K miles engine with another one as a spare along with new cats and misc. parts.
I wasn't even masking it to tell you the truth. It made the clicking noise no matter what I did to attempt to alleviate the issue.
I swapped a motor already several years ago that had the same issue, and I am aware it is also an issue with 350 Z's that have the same engine.
I plan to ride the car until the wheels fall off (the new Pirelli P ZERO tires are my best overall tires, even compared to the Michelin Pilot Super Sport that I owned for several years). I will get another motor when the time comes (when the car isn't running at all, pretty much).
Regarding the modification...daisy chain? For what specific purpose?
No other issues as well with the mod - the puddle lights always garner compliments, even to this day! :woot:
cruzad3r
i asked because i want to know if it's going to be an issue (power-wise) if i linked several strips together to run the underbody.
moedawg140
LI Quad
(15mm F, 10mm R)
Focal 165KRX2 (F)
Alpine Type-X 10"
RF CPCD10-03
Morimoto 4,300K H11
cruzad3r wrote:i asked because i want to know if it's going to be an issue (power-wise) if i linked several strips together to run the underbody.
I only used one strip of LEDs for each side as noted in the review. My thinking is as long as the total power requirements of the LEDs are less than a regular stock bulb, there shouldn't be any issues. If you want to daisy chain, as a precaution, you may need to purchase another fuse or two from the dealer in case the stock one blows. If you choose to daisy chain, let us know how the entire process goes (with pictures would be awesome as well).
Thanks in advance!
