Cool Thanks for all the info. I'm gonna swap it out today.slinger5150 wrote:Posted this for you in the mechanic forum. Hope it helps. Drop the lower driver dash cover. Two phillips screws on upper and lower right of panel. Remove two 10mm bolts holding brake release on left side of panel. Remove two 10mm bolts for hood release on left of panel. Pop panel off. Now on right upper side almost against side of radio there's a black relay. This is the flasher relay.
Lol a thread you responded to back like 10 years ago helped me quickly identify the problem I was having when my brake lights suddenly remained on when I came home.
