AJVersa »
https://forums.nicoclub.com/ajversa-u197282.html
Sat Jan 12, 2013 3:26 pm
The turn signal lamp, PY21W (BAU15s) comes as single filament only. It has a strange 150 degree offset lug arrangement. So the solution is to hardwire new 1157 (dual filament) bulb sockets. Connect the low beam side to the parking light. The high beam side connects to your existing turn signal wire. Use existing turn signal ground. See the FSM, LT.pdf for lighting system schematics.
If you use LED lamps you'll need to add load resistors to the turn signal circuit, but not the parking lights.
