ka24hardbody wrote:oh ok i see. how much clearance is inbetween the wheel and wheel well? I have 3 inch blocks on mine and Id like to flip mine but gotta buy new u bolts cuz one of mine are bent.
you will hit your frame before you rub tire in the rear (DEPENDING ON WHEEL COMBO)
i still have an inch and a half between frame and axle, i had to remove the rear bumpstop, i have never hit the frame........ the tires im running are 250x45x16
you can redrill the hangers aswell but if you do all three you will need a notch in your frame. but either redrill or leaf flip with three inch bolts gives a nice stance.
that garage miniz truck is beautiful 4 link with coil overs
where the hell did the OP go? lol
