notwell »
https://forums.nicoclub.com/notwell-u140605.html
Tue Aug 11, 2009 5:29 pm
Hey guys,
New to the NICO board. I have a 2002 I35, and found this posting. I was having similar problems, and still am, and wondered if you might be able to help.
Started off with the blower motor going out (display would indicate blower was running, but nothing happened). Bought a replacement at Autozone. As I think I saw on this posting, the Autozone part only had an orange wire and the black ground. When I wire the orange blower motor wire to both the original wires in the I35, and ground the black, the the blower now works, but only blows on MAX speed, even if I turn the A/C off. Basically, looks like I fixed the blower issue, but now either created another issue or something else is wrong.
I saw in the post that you may have had the same issue. What did you end up doing to fix the problem?
And to let you know, I am an ABSOLUTE novice at car repairs, and know little to nothing about the wiring stuff. I've sunk A LOT of money into this car recently, so was trying to avoid any further major expenses and also try to learn how to fix some of this stuff myself.
Thanks in advance for any help/advice you might be able to give.
