94Q45Beast »
https://forums.nicoclub.com/94q45beast-u244772.html
Wed Mar 11, 2015 6:49 am
I installed the new coolant temp sensor...the old one looked like it was fished out of the Titanic..car ran great, no more stalling. but still I had a high idle at 2000 rpm in "Park" and "neutral" positions. when I ran the car for a while the idle dropped to 1500 rpm. in "reverse" or "drive", the car idled at 700 - 1000 rpm, also in first or second gear..there is no engine braking, like if I start driving and take it up to 2000 rpm, it stays there until I hit the brakes. btw. I changed the transmission fluid, all I did was open the drain bolt and measured how much came out and poured the same amount of fresh oil back in. I used Valvoline Max Life Dex/Merc automatic transmission fluid from autozone, on the back it said it could be used for Infiniti/Nissan Matic D, and that's what the dealership told me I needed, atf Matic D, the dealership was selling each quart for 20 bucks. this morning when I was driving the CEL light came on, and now I went to check for codes and I'm getting code 55, whats going on?
