nitink »
https://forums.nicoclub.com/nitink-u43714.html
Thu Dec 28, 2006 6:46 pm
Tranmission will slip due to excessive heat or insufficient oil pressure or worn gears.
Most of the time rebuilt convers only non metal parts, so I guess gears were never changed and for 16 yrs old car no wonder they wear out.
You can still try for heating & oil pressure
0) Check tranny oil if its not black try following1) put in a bottle of seafoam transtune and drive around a bit 2) flush transmission and change filter & gasket (flush first & than change filter & gasket that will bring crap out of torque convertor, use penzoil or castrol tranny oil , they are thicker and hold better in heat than chevron)4) test drive and if it does not slip for say first 10 minutes and then start to slip heat is causing slip3) Put a bottle of lucas tranny fix4) Put in an external tranny cooler (buy something on ebay for 20-25 bucks)
