Welcome to NICO!
Yeah, Villager and Quest were the exact same vehicle, only difference was the badging and tail light housings. You can confirm the trans model in both cars by checking the ID plate on the firewall. It'll have a bunch of info including VIN number, engine code (VG30e) and trans code (should be very similar to the ones we talked about above, like RE4F04A) in addition to paint codes and some other stuff. If the two match, you're set for sure.
The plate look like this (HUGE picture, but the only half-decent one I could find quickly with google). It's the TRANS AXLE line that you're looking for.
http://asavage.dyndns.org/Nissan/Sentra ... ic_20b.jpg
Unafraid wrote:Also, is there a noob section where I can ask questions without an angry overworked moderator banning me? Thanks, I have about five questions that I can't find answers for...
No worries. Feel free to post up in the Quest forum and you should be set. No need to worry about angering the staff...we're here to help. Plus, banning takes more effort than answering your question anyway.
If you've got more technical questions, you can also try the Online Mechanic section:
nissan-online-mechanic.html
