klebaoget »
https://forums.nicoclub.com/klebaoget-u171390.html
Wed Aug 24, 2011 12:02 pm
Yes.
Let me tell you what happened for you to understand.
The GT-R arrived in safe mode, 2.4.6 gear engaged.
The consult-3 code 2714 indicated the solenoid B.
Accomplished the learning CLUT gear for many times.
After cleaning the range of Solenoids and pistoes.limpei error codes, the module did not charge more than the 2714 code.
but the marches continued engagement with 2.4.6, I tried to do the learning but not CLUT gear consegui.com the consult-3 performed the desingage gear, and exchange never engage the gear.
Vauvulas removed the body and one of the pistons were installed wrong.
following a manual I found on the web, I set the piston in the right way, disassembled and cleaned the whole I am now checking Solenoids, as a piston in each game is pressure to move fluid using own box.
Have not know what u fazer.vou reassemble and test.
