1.) This is unwarranted speculation! To follow this to the logical conslusion, it is better to operate an automatic transmission with crud and expired ATF in it than new ATF. If this is so, why do not AT come with old fluid and varnish pre-installed?tfvesquire wrote:1.) At 140K with no history of trans service I don't think a flush is a good idea. What may happen is that all of the crud and varnish on your clutches and seals may get washed away and it will slip, stutter even more.
2.) You should try to drain and fill the system yourself (or have a shop do it)and see if just putting in fresh fluid helps. If the fluid looks a little dark, but doesn't smell burnt, then you might get lucky.
Yeah, I think this may qualify as an urban myth. In years of reading this forum, not once has an Infiniti transmission suffered any problems from a flush.tfvesquire wrote:At 140K with no history of trans service I don't think a flush is a good idea. What may happen is that all of the crud and varnish on your clutches and seals may get washed away and it will slip, stutter even more.
Purchase 16 quarts of ATF from your local auto emporium and a 99 cent drain pan, get out your wrench and simply unscrew drainplug, let the 4qt drain, replug and refill....go for a 5 mile drive...........repeat entire process 3 more times, and you will have effectively replaced 85% of your old fluid- fast,easy,cheap,safe, and effective.pirenuri wrote:I have been having some shifting problems and I was recommended to flush the fluid.
Jiffy Lube offered me two options;1- 69$ service that flushes only half of the fluid.2- 139$ service flushes all (including fluid in Crankshaft).
But neither of them includes opening the pan and cleaning parts or replacing the filter.They told me that there is no need to do that for 98 models.
Should I try either one of the options? if so which service worth spending $$? Or should I try different service center?
Thanks
And 15% of the old contaminated fluid and 100% of the varnish and all of the detritus that won't flow out under gravity.qship96 wrote:
Brian, you might want to let the engineers at Nissan know that, as they ONLY recommend the drain/fill procedure{ no machine flushes} for the G50 and Q41, and you can also let my 222,000 mile perfectly operating original tranny know that also!maxnix wrote:And 15% of the old contaminated fluid and 100% of the varnish and all of the detritus that won't flow out under gravity.
I see no savings here, only partially mitigated abuse.
LMAO! My tranny is still operating great with 194k miles and no tranny cooler. I'm doing this to see how long it last againt other board members who say that this is greatly needed. If my tranny goes at 215k (which I doubt), I'll just get a remanned one. There is no way I will complain about a tranny after it last well over 200k. My next tranny service is scheduled at 205k but I won't go with M1 this time around.qship96 wrote:
The FGY33 has neither of the latter, just the coke can in the bottom of the radiator heat exchanger design (more cost cutting).Q45tech wrote:Many members confuse the 90-93 tranny design with the improved reliability 94-96 or the further improved and less engine stressed Q41 97-01. The ~~10% lower peak engine torque of the 97-01 does wonders for the improved life of the design.
Along with dual heat exchangers and extra atf filter.
JOHNQ wrote:a drain and fill is all you need to do. maybe repeat it once more and add redlubegard and if desperate the lucas trans fix but if your trans shows no improvement then your trans is toast and will not get better with a 100% fluid flush.
I wouldn't put lucas in the tranny.JOHNQ wrote:if you dont have too major of a problem to begin with then there is little room for improvement. i was answering to the OP. but if you too want to make your shifting more smootherand did what you stated then try the lucas trans fix and let us know what you think
