Vmo »
https://forums.nicoclub.com/vmo-u29413.html
Sat Mar 01, 2008 4:09 pm
get the transmission warm by driving a little bit...
there should be a drain bolt on the underside of your transmission - just like draining your oil. As far as exact placement goes do a search in either infiniti online mechanic or the QX4 forum. Also find out if you have a filter to replace.
Typically you refill it in the neck where your dipstick is located with a small funnel.
Filling it to the right level is easier if you measure the volume of what you took out (assuming the level was correct beforehand).
Start the car, move the transmission lever through the different positions and that's about it. If you can change your oil you can do it. Sometimes it's tricky to gauge the level but no biggie.
